You and me too .......... Mines not going to be ready til Monday or Tuesday!Weiß-sechs wrote:Oh well .........these things come to try us.......
Engine all reassembled, fully reinstalled, pressure tested cooling system & running up to temp to top up ATF and check all is well.....
All isn't well; looks like a coolant pipe has pinholed at the back of the engine and misting out under full temp conditions, looks like the inlet fanimold has got to be removed again.....
And I was really looking forward to burning a tank or two of V Bastard tomorrow
Turbo options
Re: Turbo options
950 nm torque!
Ohh running bridgestones because they are the best
- Weiß-sechs
- 5th Gear
- Location: Everywhere & nowhere baby, that's where I'm at...
Re: Turbo options
Just a quick one people.....any of you guys (& gals Panda) running uprated injectors?
The hybrids are pushing a pretty constant 25 psi
but obviously the map atm isn't providing anywhere near the amount of fuel required for such boost, hence it's running quite lean.
My mapping man is currently reducing the boost while increasing fueling to more piston & valve friendly levels via the ecu rather than the ballache involved with re-springing the actuators (the adjustable actuator rods haven't made a great deal of difference so it could mean stronger springs) but it may be that with the other mods such as dp's etc the standard injectors may not be able to flow enough.
So, any recommendations on uprated injectors if needed?
Cheers all
Cheers all
Re: Turbo options
I will check when I get in and see what's on mine......I do know I am running an uprated fuel pump
But I am rather busy at the mo.....care to guess why
950 nm torque!
- Weiß-sechs
- 5th Gear
Re: Turbo options
Panda sex? I've heard that takes some time..
Re: Turbo options
950 nm torque!
Re: Turbo options
She'll be buring V-bastard, at a guess.
The injectors should be fine but you'll need a better pump and reg.
- Weiß-sechs
- 5th Gear
Re: Turbo options
Ahhh....much better than sex getting the beastie back, how she feel?amanda1 wrote:Ohhhhhh very closeWeiß-sechs wrote:Panda sex? I've heard that takes some time..![]()
- Weiß-sechs
- 5th Gear
Re: Turbo options
Thanks, I'll look into it and hopefully get the damned thing back soonbam_bam wrote:She'll be buring V-bastard, at a guess.
Re: Turbo options
Just got in......I have standard injectors but a loba fuel reg and pump.
950 nm torque!
- Weiß-sechs
- 5th Gear
Re: Turbo options
Just got in?? The wife won't be seeing me for days when I finally get mine backamanda1 wrote:Just got in......I have standard injectors but a loba fuel reg and pump.
Cheers for that anyway, I'll get shopping around
Re: Turbo options
I don't have a wife to hide from when I use mineWeiß-sechs wrote:Just got in?? The wife won't be seeing me for days when I finally get mine backamanda1 wrote:Just got in......I have standard injectors but a loba fuel reg and pump.![]()
950 nm torque!
Re: Turbo options
Hahaha oh yes .....she feels soooooo much better ( unless I think she's does due to the almost 00000 fig amount she has had spent on her and no there are not too many zeros in there!)Weiß-sechs wrote:Ahhh....much better than sex getting the beastie back, how she feel?amanda1 wrote:Ohhhhhh very closeWeiß-sechs wrote:Panda sex? I've heard that takes some time..![]()
950 nm torque!
Re: Turbo options
You need to get a data logger on the ECU and check your injector duty cycle at the top end of the rev range, plotted against boost and AFR. The standard injectors are quite small.
How far do you want to push the turbos & do you have a flow chart for them? At the moment, I'd start by seeing what my injector %DC was when I had the right AFR at peak revs, the size from there.
Recycling dinosaurs for fun
- Weiß-sechs
- 5th Gear
Re: Turbo options
Cheers fella, tbh a wee bit technical for me but I can certainly pass on the advice should we have problems, it'd be good to know if a) anyone else has gone to higher flowing injectors, b) what boost you're running and c) where they're sourced from.
I'm hoping I'll get sufficient fueling through the originals to run as close to 20 psi as poss, it's good to know that the turbos are good for 25 psi straight out of the box.
Just off topic and purely as an observation........your new avatar is fookin scary/ugly/disturbing
Re: Turbo options
Thanks, it's a self portraitWeiß-sechs wrote: Just off topic and purely as an observation........your new avatar is fookin scary/ugly/disturbing
Some tuners will turn up the fuel pressure and change the fuel pump for north of 520bhp
Users browsing this forum: No registered users and 584 guests
