Water in rear passenger footwell, few q's
Re: Water in rear passenger footwell, few q's
Post by Shoppinit » Mon Jan 27, 2014 5:56 pm
What's the state of the contacts? If they're corroded you'll need to clean them.
You might be able to revive it by re-soldering the components on the PCB. I fixed a water damaged ECU like this.
Smokes
Post by Smokes » Mon Jan 27, 2014 6:04 pm
The pins that the plugs plug in to look perfect and shiny. Can you actually open up the unit? Car is away from me at the moment but can't remember if it was a sealed unit.
Thanks again
Noggy Blue RS6!
Rover 220 Turbo Track Toy!
Weiß-sechs
Post by Weiß-sechs » Mon Jan 27, 2014 7:44 pm
Smokes wrote:It works fine when you turn the key in the door to lock, when you unlock it just unlocks the drivers door
I haven't tried on my RS6 but on my other Audis a single turn of the key in any door lock will only open that particular door/tailgate. They need a "double tap" to operate the central unlocking.
Doesn't help with your ECU problems I know, but hopefully does de-mystify the locking/unlocking system a little.
bilko1
Post by bilko1 » Mon Jan 27, 2014 10:05 pm
It does come apart quite easily, it's just plastic clips.
Smokes
Post by Smokes » Tue Jan 28, 2014 2:54 pm
Okay whipped it back out today..I'm guessing there's not meant to be two gold coloured pins :roll: :x I'll get a new box ordered but one last question, does this box also control the aircon to some degree? Aircon switches on and can things moving when you select demist/upper vents etc but no air at all blows out?
Noggy Blue RS6!
Nobby
Post by Nobby » Tue Jan 28, 2014 2:58 pm
You really need VCDS to check whether you have any problems with your HVAC. Could be flaps not moving/broken pentiometers or just rusty connections.
Daytona RS6 Avant
Post by Shoppinit » Tue Jan 28, 2014 3:00 pm
Might be as simple as a blown fuse for the fan.
Smokes
Post by Smokes » Tue Jan 28, 2014 3:27 pm
Okay cheers guys, turning in to a f'in nightmare this :(
Noggy Blue RS6!
