The engine's been out for almost 5 weeks now
Fair price?
You're not going to be able to get much out of the hybrids without lowering compression. The increase in lag will be imperceivable, you're running a 4.2L, not a 1.0L. Again, without CLG and tubulars it'll be hard to increase boost and get it out of the engine, keeping in mind the that you'll also need to support flow in with custom intakes. Which brings us full circle, the limiting factor in all of this (assuming everything is supported and is copacetic), the RS6K04 hotside is the limiting factor on a 4.2L (not so much on the 2.7L or stroked 2.7->3.0L). Head skimming ain't that expensive but you should be ready for it since the heads are being lifted.Weiß-sechs wrote:The terminology used was "looking a bit crusty". The engine has covered over 120k with no record of ever having head gaskets changed plus the hybrid turbos are going to add quite a lot of extra boost so it's probably a sensible move to replace them now while there's plenty of room to manoeuvre.
You're about right on your costings plus 3 hours labour
What benefit will I see from the lower comp gaskets do you reckon? Won't that increase turbo lag? Will a head skim have the same effect? Seems this isn't going to be as straight forward as I thought
Bladerider wrote:Not sure why you need GT30's
Big 2860's will see you to 650+ and 2871R's will see you pretty much to 750+ and if you get a GTX2867R (or similar billet wheeled HTA type) you should see the spool times getting almost back to standard i would have thought.
J.
I would agree on lowering gaskets and cams to be fitted :Weiß-sechs wrote:Nipped round earlier to see how we're progressing.
Settled on standard head gaskets in the end; lower comp are an option but too much of a compromise as far as longevity is concerned, far better to use lower compression pistons if going down that route but can't really justify a full engine rebuild ATM......
Bores and head a looking good for an old 'un
No, not planning on skimming but haven't seen bank one yet, hopefully it'll be good.sweegie wrote:Head does indeed look in great condition. Are those fret marks around the fire rings, or just a bit of discolouration? Don't skim unless you have to
Users browsing this forum: No registered users and 81 guests
