Moving Number plate
chriscollie
Moving Number plate
I've seen someone's car on here with the number plate moved to the bottom of the grille. Haven't looked at it but does a full size number plate fit low down? And is it just a case of relocating?
Re: Moving Number plate
Can't remember who it is now?
I've just ordered a small front plate..3" x 6" so il experiment and report back!
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Me and Golf and others... 3 x 6 " is too small m8.RS6chris! wrote:Can't remember who it is now?
I've now moved the small plate back up stairs but without the plate holder.
Also, if you have the stock OEM front splitter ( I have the Carbon MTM), the plate will be sitting right on the edge.
What size is your plate Classba?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
It's 3.5" x 13" but I have a 5 digit plate.RS6chris! wrote:What size is your plate Classba?
I have a 3 digit number plate and I got stoped by the police my plate was 300mm x 88mm with full size letters on it they told me it has to be 111mm in height so. There is a border so the camera can read it so I'm having a custom plate holder made out off carbon fibre and my new plate will be 280mm x 111mm hopefully that will keep them off my back
I've been stopped before but not for the number plate and they never said anything about it even though they were looking at it to check with their base. Also, the congestion charge cameras have no problem picking it up and that was when I had it on the bottom.S5 tony wrote:I have a 3 digit number plate and I got stoped by the police my plate was 300mm x 88mm with full size letters on it they told me it has to be 111mm in height so. There is a border so the camera can read it so I'm having a custom plate holder made out off carbon fibre and my new plate will be 280mm x 111mm hopefully that will keep them off my back
I suppose it depends on what area you live in aswell but it did fail the MOT with it on like I say they only picked up on the height the length was no problem but I just can't be doing with be pulled over about it
classba wrote:It's 3.5" x 13" but I have a 5 digit plate.RS6chris! wrote:What size is your plate Classba?
I'm 5 digit too.....I was half asleep last night when I ordered mine...front as you say is too small....think I'm going to go with size you have stated.
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
chriscollie
Mine is standard 7 letter plate. I could get rid of the holder and have a slightly smaller plate but not sure the smallest legal size I could get away with?
At the moment I use the OEM front plate holder on a shortened plate.
I removed the OEM holder cut a couple of inches from middle and plaggy welded it back together, smoothed of joint..re sprayed gloss black.....still uses original securing lugs too.
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
I've done away with the holder and just drilled 2 holes on the number plate where the holder holes were and used normal number plate screws with caps. For your reference the distance for the 2 holes is 10 inches.
Users browsing this forum: No registered users and 83 guests
