Parking Sensors
- Firestarter
Re: Parking Sensors
Also if I need replacements do they come colour coded as the ones on eBay appear to all be black?
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Re: Parking Sensors
Firestarter wrote:Also if I need replacements do they come colour coded as the ones on eBay appear to all be black?
Yep it's a bumper off job, then they kind of just pull out lol.
As for paint, I went ro halfords got the paint match ( spray paint ) already had a tin of primer (£1 for poundland ) & also a clear laquer. Then a light coat of each. Came out good
- PetrolDave
Re: Parking Sensors
+1adsgreen wrote:worth giving them a clean - they are essentially like audio speakers so the central "core" needs to move. if its jammed with dirt and crud then it could register a fault.
After a downpour earlier this week enough crud bounced off the concrete I was parked on to cover the sensors in a thin layer and the instant I went into reverse the sensors did a continuous beep.Washing them sorted the problem instantly.
Re: Parking Sensors
No need to remove - you can see the groove that needs to be clear on the outside.
Careful use of here ash usually does the trick but not to harsh as they are fragile.
Re: Parking Sensors
I've read that a few times and it still doesn't make any sense to me!adsgreen wrote:No need to remove - you can see the groove that needs to be clear on the outside.
So the sensors can be removed by levering them out carefully?
Re: Parking Sensors
also need to be careful painting them or if you have had any paintwork done. one layer of paint on the sensor properly done is fine but if you paint them again the extra layer of paint can mess the sensors up too. pretty sure that's one of the things they say about checking on ELSAWIN when sensors are malfunctioning. (that and dirt, number plate not sitting flush on mounting plinth etc)
Re: Parking Sensors
Look at the sensor - you will see an outer ring and an smaller circle.guffy wrote:I've read that a few times and it still doesn't make any sense to me!adsgreen wrote:No need to remove - you can see the groove that needs to be clear on the outside.
The outer ring is a mounting frame used to fix the sensor to the car.
The inner circle is like a speaker cone - it oscillates very fast in the sensor frame to generate the ultrasonic waves.
If there is crud in the groove/slot between the movable sensor circle and the outer frame then this can disrupt the generation of the waves. You don't need to remove the sensors
- Firestarter
Re: Parking Sensors
CheeRS Ads! I'll give this a goadsgreen wrote:Look at the sensor - you will see an outer ring and an smaller circle.guffy wrote:I've read that a few times and it still doesn't make any sense to me!adsgreen wrote:No need to remove - you can see the groove that needs to be clear on the outside.
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
- Firestarter
Re: Parking Sensors
Guys
I have tried cleaning each of the rear sensors by getting my thumbnail and going around the inner circle groove, however no joy
Is it advisable to use a small flathead screwdriver and gently go round the inner circle groove? Also when I put the car in to reverse the led flashes but I don't get the beep?? Its really p1ssing me off as I nearly reversed in to a post the other day so desperately want these back working
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
- PetrolDave
Re: Parking Sensors
Wonder if it's worth doing a VCDS scan to see if they are any fault codes on the parking sensor?
Re: Parking Sensors
Well the cheap £16 sensor from ebay actually works. No error codes now and both front and back sensors are operating correctly again.
You will need to buy paint and lacquer as well if it is not one of the inner front ones that are faulty.
Misano Red RS4 B7 Avant
- Firestarter
Re: Parking Sensors
Good call Dave....WTF didn't I think to do that as I have VCDSPetrolDave wrote:Wonder if it's worth doing a VCDS scan to see if they are any fault codes on the parking sensor?
I'll get me coat
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Re: Parking Sensors
As far as i know they are the same part - just they need spraying to tghe right colour
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 115 guests
