Tpms.....are these the right ones ?
coffey555
Re: Tpms.....are these the right ones ?
Post by coffey555 » Thu Jan 09, 2014 11:10 pm
I don't think it does, it just reads back 4 pressures and if one of them drops below a certain limit it flags up the alarm in the DIS.
Each one will have a different address but the system does not know on what corner of the car an individual sensor is fitted.
Misano Red RS4 B7 Avant
PetrolDave
Post by PetrolDave » Fri Jan 10, 2014 10:52 am
WillRS wrote:how does it identify which wheel is which out of interest?
VCDS just tells you wheel 1, 2, 3 & 4 IIRC - there's no way for it to tell which sender is on which wheel (that I know of...).
dave635
Post by dave635 » Mon Jan 13, 2014 11:09 am
Plugged in at the weekend & found these 2 fault codes in the TPMS module, anyone seen these before or can decipher?
Cheers, Dave.
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
VCID: 2A5D341A8646CC4EEA7-5160
2 Faults Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 86.0
Voltage: 13.80 V
(no units): 19.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01833 - Antenna for Tire Pressure Monitoring; Rear (R96)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Time Indication: 0
Freeze Frame:
(no units): 49.0
Voltage: 13.60 V
(no units): 130.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
2007 RS4 Avant Silver (now sadly sold), 1989 BMW 635csi.
coffey555
Post by coffey555 » Mon Jan 13, 2014 9:38 pm
Looks like your aerial has failed as it is showing a fault code for that (01833) and you are getting no data back from any of the sensors in the wheels.
The aerial is located behind the plastic mesh next to the drivers side exhaust http://forum.rs246.com/viewtopic.php?f=35&t=89015
Try cleaning the electrical connections on the unit and the connector plug first and if that does not work you will probably need a new aerial.
Less than £100 from Audi. Where are you based? Maybe try swapping the aerial over with another forum member?
dave635
Post by dave635 » Sat Jan 18, 2014 7:51 pm
update - found the module behind the rear mesh (thanks for the tip), disconnected & retried VCDS. Same error with or without the module connected so I assume its dead. Cleaned connector & checked wiring, seems ok.
switched off TPMS so I don't get the error every time I start the car, will order replacement on Monday & update after fitting.
cheers
coffey555
Post by coffey555 » Sat Jan 18, 2014 9:22 pm
I am pretty sure my old aerial still works if you want to give that a try? I fitted a new one with no success so in my case I think the control module is broken but will hopefully find out more tomorrow.
dave635
Post by dave635 » Mon Jan 20, 2014 2:06 pm
it would be handy to try one without buying new just in case the problem is something else, i'm in the Aberdeen area, where are you?
cheers.
RS6chris!
Post by RS6chris! » Tue Mar 04, 2014 6:31 pm
Quick thread reserection!!
I've posted on C6 forum but it's busier over here and I need a quick answer.
It says on my new sensors...(bought the ones for eBay on this thread)...tighten to 4nm?
Does this mean the valve into the sensor OR the metal "sleeve" on the valve itself?
New wheels are on tomorrow and just need to let wheel refurb mam know?
Chris
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Users browsing this forum: Bing [Bot] and 149 guests
