what it does?
DanX
what it does?
Post by DanX » Thu Jan 02, 2014 9:37 pm
Hi guys, got this round button behind the square button ( steering adjustment) , what it does? . Thanks !
Rs6 2004 Grey
Mr V10
Re: what it does?
Post by Mr V10 » Thu Jan 02, 2014 10:08 pm
Comfort entry I believe. So the steering wheel will raise when you turn the ignition off so you don't hit your knees on it when getting out. My C6 and 1995 A8 have it too! My C5 didn't, think it's only available with memory seats so an optional extra.
ahoooga
Re: what it does?
Post by ahoooga » Thu Jan 02, 2014 10:55 pm
Electric adjustable steering column was a £345 option on 2003 models.Worked as 'Mr V10' described above.There wasn't an option for memory seats though ( surprisingly)in that years price and options list.
Re: what it does?
Post by Shoppinit » Fri Jan 03, 2014 10:03 am
Yup. Concur. I have never, ever pressed this button. I didn't notice it for a couple of years and now I don't want to jinx myself by pressing it.
ahoooga
Re: what it does?
Post by ahoooga » Sat Jan 04, 2014 2:54 pm
Edit **Wrong info, see my next post further down. Not deleted as the thread would read wrongly**
I've been thinking about this .
If i recall right, there IS a memory function for the seats and steering wheel position.
Its key dependant, so 2 people can use 2 different keys and the wheel and seats remember which key used which positions for seats and wheel.
Totally forgot all about it , as i only ever use the One remote.
Although a handy little 'toy' , I disabled mine when i was having battery problems last winter ( battery was knackered).
As Mr V10 said, its only available as an optional extra and DOES have a memory function.
EDIT - The correct info is in the following Two posts
Re: what it does?
Post by Shoppinit » Sat Jan 04, 2014 3:05 pm
No memory seats on the RS6 except the US, non-Recaro version.
ahoooga
Re: what it does?
Post by ahoooga » Sat Jan 04, 2014 3:25 pm
Totally correct Shop :bowdown: . I was thinking wrongly about what the two remote fobs did.
I just looked thru the manual , but cant find the bit i was after about 2 keys and 2 memories.
What the electric steering adjuster does do , is remember what position the wheel was in/at for each remote key. So the mrs can have the wheel set right forward and up , and when you get in with your remote ,it will go to what you set the wheel at . Just another gadget to go wrong though :audibash:
I knew it was something that remembered which key was used
