Dehumidifier Advice After Water Leak
S4quattroCab
Post by S4quattroCab » Thu Jan 02, 2014 2:45 pm
Guys,
Are the £50, ebay, smallish 500ml a day draw capacity portable dehumidifiers any good for drying the carpets and soundproofing out in my car following a water leak into my passenger front and rear footwells or do i need an industrial type machine. The carpet is soaked to the point of water coming above my fingers when i press it down. I would also point out that i will lift up the carpet and try to remove as much visible water as possible. I may even remove the carpet fully yet im not sure. Just wanted to know if these small units will be ok to try and remove some of the moisture form the fabric/carpet or would it be a waste of £50.
Just another problem to add to the list,
:audibash:
Many thanks in advance,
2004 Black B6 S4 Cabriolet Quad Milltek Non Res
S4quattroCab
Re: Dehumidifier Advice After Water Leak
Post by S4quattroCab » Thu Jan 02, 2014 4:27 pm
Have now ordered one so I'll soon see if its up to the job.
adsgreen
Post by adsgreen » Thu Jan 02, 2014 5:22 pm
"ages".
As in weeks. I guess the problem is that the airflow in the car isn't great. I used my parents one when I spilt a load of water in the boot of an old car. Got most out through sponging and thought I'd give it a go... Well after two weeks it was still damp. In the end took the whole carpet out and couple hours in the sun job done.
Doesn't help this time of year being so cold and wet.
I'd say see if you can borrow/rent a decent workshop vacuum that can deal water. Should be able to get most of it out that way and then it's a case of good ventilation (if you can get something between the carpet and the floor to make a gap then it really does help. A good test for a decent Shop vac - if you can use it without ear defenders on then it ain't powerful enough :)
S4quattroCab
Post by S4quattroCab » Thu Jan 02, 2014 6:55 pm
Ok adsgreen, thanks for your reply.
I needed to order by 15:00 to get it despatched today so thats why i did it quickly. I'll give it a go but won't be expecting too much I suppose. :(
Thanks anyway
Keaney
Post by Keaney » Sat Jan 04, 2014 1:42 am
Personally I've always had a ebac one, last years and perform very well.
Tried a cheap one before and it wasn't worth turning on, yours may be different though. Good luck
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Post by Ian_C » Sat Jan 04, 2014 6:59 pm
S4quattroCab wrote:The carpet is soaked to the point of water coming above my fingers when i press it down.
Sounds ridiculous but attack it a Dyson first. Had the filter leak on the presurised hot water radiator circuit, lots of dirty radiator inhibitor water. The carpet was NOT soaked to the point of water coming above my fingers when pressed down, but I couldn't believe the volume of water it shifted into the Dyson!
Return to “General Car Chat”
Users browsing this forum: No registered users and 83 guests
