HELP engine noise what is the problem
2.7 V6 30v biturbo - 380 bhp
hataw
Post by hataw » Tue Dec 21, 2004 9:55 pm
Guys i am getting this noise from the engine when i start it in the morning when it is only been parked over night it sounds like valve tops when the engine gets to running temp it goes away what do you think is the problem
simple1
Post by simple1 » Tue Dec 21, 2004 11:08 pm
All rs4 do this initially, mine does it especially when parked up for a while, even a fresh sump full of oil has not stopped it after long periods of not using it, if used every day it will do for a second or so then go dead quite...when was the oil last changed? I know the variable service time is usually about 10k miles, but I would change the oil at least once inbetween the services.
hataw
Post by hataw » Wed Dec 22, 2004 5:19 am
I change oil every 5t k its due already as i am hitting 15t already
kiwi_mtm
Post by kiwi_mtm » Wed Dec 22, 2004 5:39 am
just to state the obvious, but you are using the correct oil ?
RED_ROCKET
Post by RED_ROCKET » Wed Dec 22, 2004 11:47 am
I get the same problem, and using Mobile 1..
993 Gt2 - Mid life crisis
RS4 B5 -(Disappeared)
Q7 - Family wagon (RIP)
Tomson
Post by Tomson » Wed Dec 22, 2004 12:11 pm
and me, asked Kim (QST) about it. He said they all do it - just everything gettiong started in the morning or some such <beep> - still bloody annoying though..
JonnyX
Post by JonnyX » Wed Dec 22, 2004 12:17 pm
Is it not because of forged pistons?
I "heard" that forged pistons need to heat up a bit and may
make a bit of noise when the engine is cold. This was from a tech
source on the web somewhere (i.e. not a used car or dealer fob
off)
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
simple1
Post by simple1 » Wed Dec 22, 2004 9:52 pm
Defo tappet rattle, not any other source for this particular noise.......my cossy is very rattley when cold, it was explained that because the engine is under some pressure, they increased tolerances when cold.......remeber the first time I started the car from cold......thought I had over thrashed it on the way home the previous night.
zorroRs4
Post by zorroRs4 » Wed Dec 22, 2004 11:04 pm
welcome 2 the club boyz.
Diesel
Post by Diesel » Thu Dec 23, 2004 12:58 am
Hydraulic tappets - very common trait on Rover V8's too. Would only expect to briefly hear them after several days of non use though...? Havent yet heard them rattling from cold on mine. D
AMD III RS4
Morpheous
Post by Morpheous » Thu Dec 23, 2004 1:13 am
More likely to be chain rattle on the variable valve timing elements, my S4 (AGB) does this on Bank 2 and will be sorted either by replacing the oil gallery one way valves under a cover in the block or the element itself.
Mine sounds like a harsh rattle when first started until the oil pressure builds up.
hataw
Post by hataw » Sun Dec 26, 2004 4:29 pm
guys thanks for the info i have to change oil soon so will do it and will see what happenes after
JochieNL
Engine noise?
Post by JochieNL » Mon Oct 31, 2005 3:19 pm
I have the same noise as stated in earlier in this topic. Only when my RS4 is started for the first time mornings. It's only a second or so but it not a good sound to hear.....
So, after the oil was changed, was it better or did you have to replace chains or the variable valve timer/chains tensioner?
Greetings from Holland.
Hutch
RE: Engine noise?
Post by Hutch » Mon Oct 31, 2005 9:42 pm
read the manual, iirc it says this noise is normal.
derdle
RE: Engine noise?
Post by derdle » Tue Nov 01, 2005 10:24 am
Mine has had a minor rattle on start-up since I bought it 18 months ago. It goes after less than a second. And doesn't matter whether I have fresh oil or end of life oil in the engine.
