Engine Start Stop
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Brooner
Engine Start Stop
Post by Brooner » Fri Dec 06, 2013 3:19 pm
Can you permanently disable the start stop feature using Vag Com as my wife is getting the a new car with the feature as a standard and according to the dealer cannot be disabled other than using the button inside but this is reset when the journey is finished.
TimDogg
Re: Engine Start Stop
Post by TimDogg » Sun Dec 15, 2013 8:45 pm
Apparently you can't, sorry - might be some fuse you could pull but that's getting technical.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
Brooner
Post by Brooner » Mon Dec 16, 2013 5:37 pm
Thanks yes thought as much the wife will just have to remember to press the disable button at the start of each trip
Ponyboy
Post by Ponyboy » Mon Mar 10, 2014 11:39 am
Why would you want to disable it? I had it on my A4, worked well and was quite pleasant at lights, relaxing even, lol.
Brooner
Post by Brooner » Mon Mar 10, 2014 12:23 pm
Just a pain as I always think the engine has stalled plus the extra wear and tear on the starter motor going on and off all the time and if turning a t a junction would be a pian with the 21" wheels the savings in fuel and emissions would be very small
Ponyboy
Post by Ponyboy » Mon Mar 10, 2014 2:14 pm
Brooner wrote:Just a pain as I always think the engine has stalled plus the extra wear and tear on the starter motor going on and off all the time and if turning a t a junction would be a pian with the 21" wheels the savings in fuel and emissions would be very small
:thumbs:
nigelw1982
Post by nigelw1982 » Tue Dec 23, 2014 10:08 pm
you can do it with VCDS you need to do the following
19 - CAN Gateway
Adaptation - 10
From drop down menu select (1) select start stop minimum temperature
in new value box put 50 instead of -50
Click do it and add to log
From drop down menu again select (2) select Start Stop maximum temperature
click do it and add to log
Voltage method
19 - CAN Gateway
Adaptation - 10
from menu select start stop voltage limit
new value enter 12 as default stored is 7.6v maximum of 12.1v
you could have Acc/Start Auth. Control module fitted to your car (address 05, HW:5Q0-959-435)
This controller has only one adaptation channel whose sole function is disabling Stop/Start. The adaptation channel descriptor is Deactivation of start-stop function and default setting is not active. Change this to active
Hope this helps
Return to “DTC / VCDS”
