Hi Clyde, I see the centres are on the inside of the barrel is the offset ET 32 like this or when the centres are in the original position? Also is the centre bore 66.1 with a 57.1 spigot in it?.
From memory LMs are front mounted from factory (as are these) so that would make them ET 32. The centre bore is 74.1mm so they can fit a host of different vehicles. Hope that helps
