N75 dumped in favour of manual boost control valve
tartan_rob
Guys - has anyone dumped their std N75 in favour of a manual boost control valve (NOT an in-car adjustable). I've heard that the pick on a manual job is better, the only hassle is setting it up initially - takes a lot of faffing around.....
On K03's it's not a good idea. It will overstress the turbos much more than the N75 will. It will give you the most aggressive boost response, but part throttle response will suffer. I ran one for a while on the K16/K04 turbos and went back to the N75.
-2001 Audi S4 biturbo (K16/K04 goodness @1.6 bar)
-2005 Golf V TDI PD
-1999 Jeep Cherokee Classic 4x4
www.NogaroBlue.com
-2005 Golf V TDI PD
www.NogaroBlue.com
tartan_rob
What types of problems did you have?Tartan_Rob wrote:Okay - swapped the N75 for a MBC and although was getting more boost was not happy with the results so swapped back. No probs or issues but lesson learnt and can now start thinking about going back to revo set-up....
-2005 Golf V TDI PD
www.NogaroBlue.com
-2005 Golf V TDI PD
www.NogaroBlue.com
tartan_rob
The spool up at high revs was great - almost instantaneous but at low revs I felt she was less responsive than with the N75. Also the boost would remain constant around .9 bar but around 5k revs the car seemed to loose accelerative force. My passsenger did not notice it but as the driver, I did. I would rather have the low down kick and torque that I get with the N75. Its a shame as as it would have been a very cheap alternative for getting a touch more power from the car....
2017 Kawasaki Z1000
2014 RS6
2014 S1
2014 RS6
2014 S1
He's right. In theory, an MBC will spool quicker than the N75. You are probably getting throttle cut. Log throttle position angle and see what happens.Dippy wrote:Jonny,
Sounds interesting - could you expand that a little?
-2005 Golf V TDI PD
www.NogaroBlue.com
-2005 Golf V TDI PD
www.NogaroBlue.com
tartan_rob
It depends on what software you are running.Tartan_Rob wrote:But how could I resolve if this is to blame?
-2005 Golf V TDI PD
www.NogaroBlue.com
-2005 Golf V TDI PD
www.NogaroBlue.com
tartan_rob
Like I said, it depends on what software you have. The "solution" involves a few mods some consider "hacks", but they work well. A Zener Diode on your MAP will allow you to run an MBC without throttle cut. This works great on GIAC X software, and not so well with others.Tartan_Rob wrote:Verruckt - okay - talk to me. What is involved in "fixing" this problem..?
-2005 Golf V TDI PD
www.NogaroBlue.com
-2005 Golf V TDI PD
www.NogaroBlue.com
tartan_rob
Well, an MBC only works if you already have some sort of remap. It won't work with a stock ECU.Tartan_Rob wrote:The big question though....would the cost of modding the car and using an MBC be more than spending £600 on revo?
Assuming you already have software, it will cost less than £50.
-2005 Golf V TDI PD
www.NogaroBlue.com
-2005 Golf V TDI PD
www.NogaroBlue.com
Rob, why not get a proper remap for your car, that will take care of all this without worrying for throttle cut or anything like that??? There's several options available out there IMHO.
About the X-chip, it's a nice chip, but heck I won't use it on K03s for anything in the world. 1.3 Bar peak and 1.0 at the redline is defo way too much for the K03s...
Mihnea
Mihnea
