Long Service - Advisories
Re: Long Service - Advisories
18.86 per litre for your information was what i was quoted,hence the 90 PREMUIM over what edge is readily available for from outside sources,Quantum out of a drum and billed for castrol edge are my findings had i not walked into the workshop just prior to it being poured into my car,anything else you would like me to clarify?
Yep, tamer has come across totally 'native' in his posts...
- Surrey Sam
Yes please, could I have a breakdown of:lengster1 wrote:anything else you would like me to clarify?
- How many millilitre of oil spillage from filling up?
Number of paper sheets used to soak up said spillage?
Was the paper recycled to meet ISO 1400 standards?
Quantity of Brake cleaner utilised to clean the associated oil smear?
Was the brake cleaner atomised during application process?
The Isopropanol content of Brake cleaner to ensure it meets VAG approved standards?
Teutonic_Tamer
Ahhhhhh - now you've clarified it, I bow to your earlier opinion. And foook me, that IS a premium - did they provide a pot of Vaseline before presenting you the bill?lengster1 wrote:18.86 per litre for your information was what i was quoted,hence the 90 PREMUIM over what edge is readily available for from outside sources,
Apologies for any confusion.
Eeeek - wtf is an official Audi stealership doing using Quantum? Quantum should ONLY be used by the independent trade sector. Official dealers should only use 'premium' brand lubes - such as Castrol (which should be their SLX Professional Powerflow range), Shell, Mobil, etc.lengster1 wrote:Quantum out of a drum and billed for castrol edge are my findings had i not walked into the workshop just prior to it being poured into my car,
Secondly, Quantum is NOT Castrol. OK, it may well be blended and packaged by BP Lubricants plc (whom own the Castrol brand) at their Belgium blending plant, and it may also use the Castrol Technical helpdesk at Castrol's head office in Swindon - but Quantum LongLife III is definately NOT the same as either Castrol Edge nor Castrol SLX Professional Powerflow LongLife III. All Quantum brews use inferior base stocks and additives packages compared to their 'equivalent' Castrol brews. Compare the TDS from them both.
I don't think so . . .lengster1 wrote:anything else you would like me to clarify?
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
Teutonic_Tamer
Whadya mean by that?D_K wrote:Yep, tamer has come across totally 'native' in his posts...
Hey no worries,the wrong oil going in was back in my b5 Rs4 days but 186 notes quoted for oil was last years annual service on my b7,hence it went into york audi instead who have been top notch over the last few years.
I've just had my OSF suspension pipe replaced free of charge today, Audi goodwillMarkmyatt7 wrote:You are totally right it's the pipes not rods. But still £900??Surrey Sam wrote:Wo wo wo...
The first work sheet that you posted says 'suspension pipes corroded' not rods. A lot of people will jump on the DRC bashing wagon because rightly so, the first two generations were not reliable coupled with poorly trained dealers who risked/did further damage to the system. So people moved their alliance to non OEM products. The third generation DRC however is much more reliable and I am yet to read of any failures. Anyway that aside, I interpreted the work sheet as the pipe which carries the hydraulic fluid to the central valve has aesthetical corrosion, this does not constitute a DRC failure. You could simple remove the wheel and clean/treat the corrosion with a product like Bilt Hamber Deox Gel and re-seal. I'm sure Unit 20 will advise correctly on what to do as they have plenty of DRC experience.
As others have alluded to, there are ways to help reduce dealer service cost and keep those Audi stamps in the SH Book. I provide my own oils and get them to price match (where ever possible) independent prices for things like Aircon servicing. It all helps and those Audi stamps will pay you back when it comes to re-sale as your potential market audience will be greater.
Leaking due to perished pipe.
Phantom Black R8 V10 plus, Capristo Exhaust
Phantom Black (B7) RS4 Saloon, MRC Stage 2
Mercedes E-Coupe 350CDi
great to hear, whichs stealer? did you do it thru Audi Customer services?nij wrote:I've just had my OSF suspension pipe replaced free of charge today, Audi goodwillMarkmyatt7 wrote:You are totally right it's the pipes not rods. But still £900??Surrey Sam wrote:Wo wo wo...
As others have alluded to, there are ways to help reduce dealer service cost and keep those Audi stamps in the SH Book. I provide my own oils and get them to price match (where ever possible) independent prices for things like Aircon servicing. It all helps and those Audi stamps will pay you back when it comes to re-sale as your potential market audience will be greater..
Markmyatt7
After getting quotes from a number of Indy garages and talking to MRC, it seems coventry Audi have totally under estimated the job that needs doing and have quoted well under what they should be charging me. So I am going to ring them up and get car booked in and ask them for Written quote.
Current Car: 2014 Nissan Quashqai 4WD (it's not my fault)
Previous Cars: 2006 B7 RS4 - Phantom Black
2010 BMW 123d Coupe M Sport
2004 Honda Civic Type R
2002 VW Golf 2.8l V6 4 Motion
Two weeks after it was serviced by Newcastle Audi, found the OSF pipe misting. I rang to book my car in, but wanted speak to their service manager to ask how they could have missed that and about missing fixings under the bonnet again. Got me booked in earlier than their service desk and told me to ask for him when I drop the car off. I was expecting to pay for the repair, but was told it is covered by Audi goodwill. The fact that my car have only ever been serviced by them for over 6 years and only covered 36K miles helps.S4WON wrote:
Ah yes, sounds fair, thanksnij wrote:Two weeks after it was serviced by Newcastle Audi, found the OSF pipe misting. I rang to book my car in, but wanted speak to their service manager to ask how they could have missed that and about missing fixings under the bonnet again. Got me booked in earlier than their service desk and told me to ask for him when I drop the car off. I was expecting to pay for the repair, but was told it is covered by Audi goodwill. The fact that my car have only ever been serviced by them for over 6 years and only covered 36K miles helps.S4WON wrote:
Markmyatt7
Car in for work today at Coventry Audi. Within an hour they phoned me "hi the work is actually a lot bigger than we originally thought, it's going to cost closer to £3000".
Luckily we got a written quote, with 20% discount! and after an hour and half of tooing and throwing! they are honouring the quote.
So £1200 for the work inc VAT.
Thank you Audi
Thank you Audi
Users browsing this forum: No registered users and 170 guests
