Rolling Road Day at QST
depending on the outside temp, mine is about 30C when doing WOT runs in 4th gear.Doug_S2 wrote:That is good - what does it get upto on the road in a low rpm to redline in 4th ? I don't have any experience of RS4s - thankssitas3 wrote:The RR software measured intake temp - the intake temp on my runs was 9.0 C
actually I've just looked at some old datalogs and the last proper run i did with block 118 saw a max intake temp of 45C at 7000 revs in September.sitas3 wrote:depending on the outside temp, mine is about 30C when doing WOT runs in 4th gear.Doug_S2 wrote:That is good - what does it get upto on the road in a low rpm to redline in 4th ? I don't have any experience of RS4s - thankssitas3 wrote:The RR software measured intake temp - the intake temp on my runs was 9.0 C
Cheers for the info - there definitely looks like a difference between the companies - I wouldn't mind knowing what losses other cars got?
I would have thought that S2s and RS4s would have similar losses - maybe the RS4 a bit more as they have fatter tyres (although I don't know if the difference would be a 1% or 10%)
SitaS3 - is that just a remap you have?
[quote="Doug_S2"]Cheers for the info - there definitely looks like a difference between the companies - I wouldn't mind knowing what losses other cars got?
[quote]
Ben, can you post your figures from the RR print-out sheet section same as mine above? your car was the nearest RS4 to mine and your power output was pretty much as expected.
[quote]
On the road, Dougs and mine were getting to about 25 degs, maybe 30 max. On the rollers were say on Dougs over 58 degs. This made the car go into its knock limit and hence it lost power. Same with mine, but we are unsure how hot mine was getting.
Tom C
VW Golf Mk2 2.0T 20VT, GT3071R, FMIC, Hi-spec brakes, 4xxbhp MRC Mapped
B5 RS4 - RS6 hybrids, FMIC, 520bhp MRC Mapped
VW Golf Mk4 20VT, K04, AP brakes, 260bhp - SOLD
Users browsing this forum: No registered users and 98 guests
