Long Service - Advisories
lengster1
Re: Long Service - Advisories
Post by lengster1 » Wed Nov 13, 2013 10:09 pm
I also have oil done every 5k in mine as these engines are quite hard on oil and i only do 6k a year in the RS
Markmyatt7
Post by Markmyatt7 » Wed Nov 13, 2013 10:14 pm
This is my receipt. Thoughts?
Current Car: 2014 Nissan Quashqai 4WD (it's not my fault)
Previous Cars: 2006 B7 RS4 - Phantom Black
2010 BMW 123d Coupe M Sport
2004 Honda Civic Type R
2002 VW Golf 2.8l V6 4 Motion
Spaceman_RS4
Post by Spaceman_RS4 » Wed Nov 13, 2013 10:30 pm
There's a link on forum to the cheapest price for the KW V3s I'll see if I can find it was around 1450 a set then you need to factor in the fitting of them and a 4 wheel geometry setup around 60-100 for ego not sure on how much to fit coilovers I'd ask someone like unit. 20 for a deal price to. Supply and fit or if you want to keep Drc unit 20 will see you right and no where near that joke of a price.
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
lengster1
Post by lengster1 » Wed Nov 13, 2013 10:32 pm
Aye pretty normal really,bit cheaper oil than castrol,if you wished you could half that bill by sourcing own oil for 80-90 quid and a couple of hours indie labour would be 100 notes not 260,youve not been had its just what there rates are and there mark up on regular items such as oil.These cars are now bordering on FAsh making any difference over a good indie service stamp.The savings far outweigh any minor possible shorfall in the cars value.That said i think enthusiasts would prefer a specialist history.
Markmyatt7
Post by Markmyatt7 » Wed Nov 13, 2013 10:38 pm
Spaceman_RS4 wrote:There's a link on forum to the cheapest price for the KW V3s I'll see if I can find it was around 1450 a set then you need to factor in the fitting of them and a 4 wheel geometry setup around 60-100 for ego not sure on how much to fit coilovers I'd ask someone like unit. 20 for a deal price to. Supply and fit or if you want to keep Drc unit 20 will see you right and no where near that joke of a price.
That would be fantastic. Thanks for help everyone. As they say - we are always learning.
Spaceman_RS4
Post by Spaceman_RS4 » Wed Nov 13, 2013 11:05 pm
Spaceman_RS4
Post by Spaceman_RS4 » Wed Nov 13, 2013 11:07 pm
Balls they left the vat off ain't that cheap now
Markmyatt7
Post by Markmyatt7 » Wed Nov 13, 2013 11:12 pm
Spaceman_RS4 wrote:Balls they left the vat off ain't that cheap now
Just seen. Quite a lot of money. Is it worth it though?
myles
Post by myles » Wed Nov 13, 2013 11:18 pm
I am in the same situation.. Mines ready for full major service , diff gear box oil change plus brake fluid change.. Iv decided to see unit 20 .. Im saving a fortune
Markmyatt7
Post by Markmyatt7 » Wed Nov 13, 2013 11:29 pm
myles wrote:I am in the same situation.. Mines ready for full major service , diff gear box oil change plus brake fluid change.. Iv decided to see unit 20 .. Im saving a fortune
Right mind made up seeking Unit 20's advice.
SoaRS4
Post by SoaRS4 » Thu Nov 14, 2013 5:42 am
Markmyatt7 wrote:Today's servi ce cost me £533 including vat and servicing. Including oil and brake fluid change. Maybe I've been conned. I wanted to keep the FASH aspect of my car, maybe next time I'll go independent garage.
Ouch, that's $893 here in Canada (which is close to the US dollar).
I don't do my own oil but my Audi tech (an indie) does it for £53.
I do my own brake fluid change though, which is only the cost of the fluid: £10.
Suggest you find an indie you trust. Most shops can do the brakes easily. For the oil change, the filter is unique to the RS4 so be careful.
And you want to use Audi recommended oil - I use Motul.
Good luck mate.
2007 RS4 | Sprint Blue Saloon | Silver Nappa and Brushed Aluminum | Premium Package | ECS Wheel Spacers | 1,000 W Pioneer sub and Kenwood amp | Canadian car
Audi Pardner
Post by Audi Pardner » Thu Nov 14, 2013 10:14 am
Mark - Mine's got a FASH and the dealer changed a leaking damper @ 44k under goodwill, but it's just turned 50k now miles so I'm thinking it's time to move to an indie (probably Unit 20 as they're nearest to me) as the mileage gets higher, the running costs increase and the dealer is unlikely to change any more dampers FOC. I change the oil/filter religiously every 5k too. Good luck.
Markmyatt7
Post by Markmyatt7 » Thu Nov 14, 2013 10:23 am
Audi Pardner wrote:Mark - Mine's got a FASH and the dealer changed a leaking damper @ 44k under goodwill, but it's just turned 50k now miles so I'm thinking it's time to move to an indie (probably Unit 20 as they're nearest to me) as the mileage gets higher, the running costs increase and the dealer is unlikely to change any more dampers FOC. I change the oil/filter religiously every 5k too. Good luck.
Thank you - I'm ringing Unit 20 today to see what they advise about the suspension rods and brake hoses. Thinking whole suspension system. Unit 20 sell Bilstein suspension kit. Unit 20 is only 40 mins away from me now.
stu
Post by stu » Thu Nov 14, 2013 10:59 am
I assume braided lines are just the same but with a braided sheath: surely they will still have the perishable rubber/latex/whatever? I have heard a few times that, yes braides are good for the track but if you have a line failure they don't just bulge and degrade braking, they go pop (almost).
I have no idea what I'm talking about BTW - just querying the rationale behind promoting braided. Thoughts?
I still get mine serviced at Audi with my own oil.
Post by HYFR » Thu Nov 14, 2013 11:15 am
Mark, your car is 6yrs+ old and 100k+ miles
FASH is not worth the premium you are paying
people talk about goodwill etc ... but at 100k miles, wear and tear will far outweight any argument for goodwill.
as lengster said, you could have exactly halved that bill, let alone what they wanted to charge you for the advisories
Users browsing this forum: Google Adsense [Bot] and 205 guests
