New Gearbox
New Gearbox
I've had my car in as I haven't been pleased with the gear changes.
Long story short; new gearbox on its way and will be here in 15 days.
Apparently total cost would have been roughly 10k. Glad I've got a warranty.
2011: 2.0T FL Octavia VRS
2010: 1.8T Octavia VRS
Re: New Gearbox
What do they think is wrong with it Nick?
Re: New Gearbox
10k !
Ouch, you would be nuts to run one of these with no warranty.
Audi S4 B8, 6mt, 462hp, 539nm, AWE exhaust with AWE resonated DP's, MRC filter
Re: New Gearbox
Well the symptoms are occasional jerky gear changes and sometimes it takes an age to engage the gear.chunky79 wrote:What do they think is wrong with it Nick?
Causes I'm unsure of yet, they mentioned internals, I'll get more info later. I'll ask to speak to the tech when I go in.
Re: New Gearbox
The issue was to do with a component in the unit which led to some oil seepage. This component is still functioning but is degraded. They said that they could replace the unit inside the box but other issues may cause problems later on. Therefore they are replacing the mechatronics unit and clutch pack.
The above is their words.
The 10k figure was parts, coding new gear box and labour.
Re: New Gearbox
As an aside; I love how C5 owners have responded to this thread. I bet most people thought this was in the wrong section!
Re: New Gearbox
We're like meerkats at the mention of gearbox.
Re: New Gearbox
Hi Nicky, would you be able to describe the process your dealer went through in order to diagnose and then authorise replacement? Technician test drive? Data logging and sending to factory?
Many thanks
Many thanks
TT RS+
Re: New Gearbox
bam_bam wrote:We're like meerkats at the mention of gearbox.
Glad it's been sorted properly for you Nick. I would say the gearbox supplier (zf?) would want the complete box back to inspect it fully. Good news they are slapping a complete box in, FREE.
Re: New Gearbox
I'm unsure exactly but it has been in for four days in total. I reckon they've done all of the above. Fishy questionTootRS wrote:Hi Nicky, would you be able to describe the process your dealer went through in order to diagnose and then authorise replacement? Technician test drive? Data logging and sending to factory?
Many thanks
Re: New Gearbox
Nothing sinister, I'm having similar problems with the gearbox in my TT RS and it's slow progress with my dealer so just trying to find out as much as I can.Nickyboy wrote:I'm unsure exactly but it has been in for four days in total. I reckon they've done all of the above. Fishy questionTootRS wrote:Hi Nicky, would you be able to describe the process your dealer went through in order to diagnose and then authorise replacement? Technician test drive? Data logging and sending to factory?
Many thanks
TT RS+
Re: New Gearbox
Difficulty you have (I guess) is a stage 2 tuned car.
Re: New Gearbox
It's back to stock and still having problemsNickyboy wrote:Difficulty you have (I guess) is a stage 2 tuned car.
TT RS+
New Gearbox
Didn't the ECU have to be opened on the 5 pot?
If they are arguing you've modified the car you are probably going to struggle.
