B8 RS4 spec Q - DRC
4.2 V8 32v FSI - 444 bhp
the911 sc
B8 RS4 spec Q - DRC
Post by the911 sc » Tue Oct 15, 2013 5:42 pm
Hi All,
I have my build week (45) for my RS4.
I havent specc'd sports pack as I am not that fussed on the 20's, sports exhaust or especially the dynamic steering.
Can anyone confirm what the standard setup is as I believe it has the 4 settings (inc user) for throttle, shift points and maybe suspension?
This is what the brochure states as std spec..
Audi drive select – changes your car’s
handling and responses at the touch
of a button to suit the way you want
to drive. Enables the driver to alter the
throttle response, the shift point of
the automatic transmission, exhaust
flap control and the power steering
feel between the three pre-set modes:
comfort, dynamic and auto or
individual mode
Electromechanical power steering
quattro® permanent all-wheel-drive with
Sports differential
RS 4 Sports suspension
with damper control
Tyre Mobility System
B8 RS4 - Daytona, Privacy Glass, Convenience pack, B&O, Pan roof, Parking advanced,Hill Hold, Heated seats.
Audi Q7 Sline plus - Daytona, Tech Pack hi, Storage pack/Towing equip.
Past - 911 C4S (997), S5, S3, TT 3.2, B7 RS4, B6 S4, Boxster, '83 911SC, Corrado G60
doodlebug
Re: B8 RS4 spec Q - DRC
Post by doodlebug » Tue Oct 15, 2013 6:04 pm
Dynamic, comfort and auto are the three settings.
nwk00
Post by nwk00 » Mon Oct 21, 2013 2:50 am
Depending on what you specced, in the drive select screen you might not get to choose certain stuff. From Chris Haris YouTube, there are 5 different options. I believe his is fully specced.
Engine/gearbox, suspension control, dynamic steering, sports differential, adaptive cruise control. If you didn't buy the option, the option is not available at all on screen.
I think engine/gearbox is standard option. I am guessing the rest are probably optional in some regions. Sports suspension with DRC is for suspension control. I saw a local car without this feature and therefore has 3 options only on the drive select screen(also without adaptive cruise control option). I suspect if you don't select dynamic steering you might even get to see this on the drive selection screen. Making the things you can play with even less. Some people might like the simplicity.
I am not sure if sports differential is optional in some regions. It is inclusive in the spec in my country. I do seem to recall seeing that it is option in a brochure in another country.
nwk00
Post by nwk00 » Mon Oct 21, 2013 5:09 am
Chris Haris test car
Local car with sports suspension and DRC.
Local car without sports suspension and DRC.
I can only guess if you don't have the Dynamic steering and sports differential options, it will be only one option for Engine/gearbox(with it's 3 settings)
eightfoot
Post by eightfoot » Mon Oct 21, 2013 2:06 pm
nwk00 wrote:
Chris Haris test car.
mines the same as this (first pic) but has dynamic exhaust sound at the bottom instead,i have sports pack not tech pack
eightfoot
Post by eightfoot » Mon Oct 21, 2013 2:09 pm
doodlebug wrote:Dynamic, comfort and auto are the three settings.
and individual with sport pack
doodlebug
Post by doodlebug » Mon Oct 21, 2013 2:15 pm
Yes, those is the three settings as overall defaults, or within each item as individual. The latter you get regardless of sports pack.
nwk00
Post by nwk00 » Mon Oct 21, 2013 3:52 pm
You mean to say there is an option for dynamic exhaust sound? Did you get the sports exhaust? What are the settings available under the dynamic exhaust sound option?
the911 sc
Post by the911 sc » Mon Oct 28, 2013 1:50 pm
Thanks all - I dont have the sport pack specced or adaptive cruise so guess will have the standard (which i am ok with). I wanted to avoid the steering as recommended by harrismonkey himself!
Graeme4130
Post by Graeme4130 » Mon Oct 28, 2013 6:32 pm
Mine shows as dynamic engine, which puts shifts into S and opens exhaust valves
Incidentally, you can just shift it from S to D bad you grf comfortable shifts and the louder exhaust remains
Users browsing this forum: Bing [Bot] and 77 guests
