FUEL PUMP CUT OUT AT TEMPERATURE
Re: FUEL PUMP CUT OUT AT TEMPERATURE
Post by chunky79 » Wed Oct 23, 2013 6:19 pm
subtacex wrote:Also if the crank sensor was faulty it would have an adverse effect on the car when it was running, but mine runs fine when running.
This all seems temperature related as mentioned origionally
Hmmmmmm. Did you say this in the helpful site?
A thank you to the helpful ones on here would help mate. :thumbs:
ahoooga
Post by ahoooga » Wed Oct 23, 2013 6:24 pm
LOL is all I'm going to say :bigwave:
What an unhelpful bunch of twits ( have I spelt this correctly ? ) we have on this forum
Post by Shoppinit » Wed Oct 23, 2013 6:37 pm
This thread is fcuken retarded.
subtacex
Post by subtacex » Wed Oct 23, 2013 7:55 pm
Already did mr chunk.....
And there are some polite and helpful people on here...to them
Thank You Kindly :jump_clap:
E28 M535i
E39 M5
IMPREZA 22B
subtacex
Post by subtacex » Fri Oct 25, 2013 8:57 pm
Does anyone have any pictures of where the crank sensor is located and can I reach it without a ramp
checked code P00322 came up again on snapon solus and have the new sensor to hand but cant find it...any clues greatly appreciated
Thanks in advance
E28 M535i
E39 M5
IMPREZA 22B
Nobby
Post by Nobby » Fri Oct 25, 2013 9:49 pm
It's called the g28 engine speed sensor by the way, so....
From audizine
' Originally Posted by tryin2vw
The engine speed sensor (RPM) G28 is located in the transmission bell housing, in front of the CV shaft on the driver side of the car. It is very near where the transmission attaches to the engine, and up about 3 inches higher than the CV joint. It is held in with one bolt and can be seen just behind the wheel liner'
Daytona RS6 Avant
subtacex
Post by subtacex » Fri Oct 25, 2013 10:22 pm
Thanks Nobby I will try it tomorrow
E28 M535i
E39 M5
IMPREZA 22B
subtacex
Post by subtacex » Fri Nov 01, 2013 12:54 pm
UP AND RUNNING !!
E28 M535i
E39 M5
IMPREZA 22B
John Johnson
Post by John Johnson » Fri Nov 01, 2013 8:16 pm
What wos it then ?
Current toys in the garage
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
subtacex
Post by subtacex » Fri Nov 01, 2013 8:18 pm
It was a dry joint on the plug expanding when hot and clearing when below 65oC
E28 M535i
E39 M5
IMPREZA 22B
John Johnson
Post by John Johnson » Fri Nov 01, 2013 8:23 pm
Happy days then :thumbs:
Rs1600i
