Water leak again
swannny
Re: Water leak again
Post by swannny » Tue Feb 05, 2013 11:06 am
Why? Dies it cool the oven down?!
Gripper1
Post by Gripper1 » Tue Feb 05, 2013 11:55 am
I don't think the intention is to bake it :biggrin2:
Probably just warm up the whole car to 30ish deg which will dry things out quickly
Daveperc
Post by Daveperc » Tue Feb 05, 2013 1:15 pm
The basic problem is that the foam backing to the carpet is anything up to 3" thick in places as it is moulded to fit the floor pan. Your best bet is a really good carpet cleaner, and lift the carpet to try to get underneath it and suck from behind (Cue Bam!) followed by a dehumidifier for a week or two.
You really don't want to leave it wet for too long - not only are the "Comfort" unit and TCU under there, but with copper cables, and aluminium crimps, you will start to get electrolytic corrosion eating away at the copper wires - and there are literally hundreds down there.
Believe me - been there and got the (wet) tee-shirt!!
Post by Shoppinit » Tue Feb 05, 2013 1:19 pm
Dave in a wet T-shirt getting underneath and sucking from behind... *shudder*
Post by chunky79 » Tue Feb 05, 2013 7:41 pm
Gripper1 wrote:I don't think the intention is to bake it :biggrin2:
Are you going to set the oven? It's ok if it is your oven but if you are telling someone you want the inside drying then they will want it doing quickly.
The air con gas is pressurised and doesn't like being warmed up.
markmad
Post by markmad » Thu Oct 24, 2013 6:20 pm
wtf are you banging on about aircon being baked for? cars are baked at 80c everyday in every body Shop in the world!
Post by chunky79 » Thu Oct 24, 2013 6:22 pm
Do you work with air con gas?
And also, wft are you bringing this back from the dead for??
Post by chunky79 » Thu Oct 24, 2013 6:34 pm
Busy doing research?
markmad
Post by markmad » Thu Oct 24, 2013 6:58 pm
apologies for bringing this back from the dead but thought it was worth a mention, nope i dont work with aircon but do run the workshop in a bodyshop and didnt want anybody to worry about aircon being baked as i really feel it isnt an problem!
peace! :kissmyrings:
markmad
Post by markmad » Thu Oct 24, 2013 6:59 pm
chunky79 wrote:Busy doing research?
oh yes i have a large puddle! :thumbsdown:
Post by chunky79 » Thu Oct 24, 2013 7:09 pm
markmad wrote:apologies for bringing this back from the dead but thought it was worth a mention, nope i dont work with aircon but do run the workshop in a bodyshop and didnt want anybody to worry about aircon being baked as i really feel it isnt an problem!
Have you ever been warned about it? Some manufacturers recommend that air con gas is removed before a car is baked.
Just noticed you have a soggy floor, hope you get it sorted. You going to put the car in the oven to help dry it out?
markmad
Post by markmad » Thu Oct 24, 2013 8:21 pm
no never been warned of it....what could happen? i plan on taking the 6 off the road for a short while whilst i sort out the problems ive been having so the carpet should be dry anyway..... i wouldn't be worried about it though.
when i worked at the sheffield vw/audi dealer a few years ago (approx 14 years) there was a rule about not baking quattro's above 65c as it fried the ecu, no idea whether it does though!
markmad
Post by markmad » Thu Oct 24, 2013 8:29 pm
by the way i dont know of any bodyshop that would remove and refill the aircon before and after bake as its not economically viable, bodyshops aint making fat stacks yo!
Post by chunky79 » Thu Oct 24, 2013 8:46 pm
What could happen? It's a pressurised system containing gas. I'm not fussed if you do it or not, but I know it can be dangerous so just saying.
markmad
Post by markmad » Thu Oct 24, 2013 9:12 pm
nah <beep> that! baked plenty of pressurised <beep> and never had anything go bang, aerosols, air con units etc, gas struts sometimes break they're seals but only recall that happening once, 80 degrees c in a spraybooth is pretty hot but not that hot if ya know what i mean, the air in the booth is hot but bake time is 30-40 mins so it would probably not be hot enough to build up enough pressure in said pressurised container to make it go boom!
a spark near a battery NOW THEY GO <beep> BOOOM!
Users browsing this forum: Google [Bot] and 244 guests
