ANOTHER REASON FOR ME TO BE ADDED TO THE YEARLY EVENT ON THE 3/11toyneg wrote:This thread is the longest we've ever had
Rolling Road Day @ AmD Essex
- Firestarter
Re: Rolling Road Day @ AmD Essex
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Same car, dyno results and logs of intake temps - cooled with axial fans and high pressure centrifugal fans, then left and cooled with one axial fan on slow speed
power drop is proportional to intake temps
http://www.MRCtuning.com
- Firestarter
Well guys
Im currently at the car with VCDS plugged in and again Im getting this fcuking fault 1 Fault Found:
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 -
Just checked the Ross tech Wiki and it says the following
18609/P2177/008567 - Bank 1; System Too Lean off Idle
18609/P2177/008567 - Bank 1; System Too Lean off Idle: Upper Limit Exceeded
Possible Symptoms
Malfunction Indicator Ligh (MIL) active
Possible Causes
Fuel Pump (G6) faulty
Mass Air Flow (MAF) Sensor (G70) faulty
Intake System leaking
Exhaust System leaking
Possible Solutions
Check Mass Air Flow (MAF) Sensor (G70)
Check Fuel Pump (G6)
Check Fuel Injectors
Check Intake System
Check Exhaust System
I've changed the MAF today but was getting this fault code prior to this.
So can anyone help me here as I am loosing faith and the will to live.
This has been going on far too long and despite me being patient I am now tired of this and just want to know what needs to be done to sort it.
P2177 - 001 -
Possible Symptoms
Possible Causes
Possible Solutions
Check Intake System
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
well I guess they should sort this for you, if it was ok before hand, failing that MRC will sort this I'm sureThis has been going on since the car came out of AmD the first week of Sept
- PetrolDave
Let's take these possible causes one at a time:Firestarter wrote: Possible Causes
- fuel pump;
are they another other fault codes relating to low fuel pressure?
what about the fuel filter? Has the tank run really low recently and dragged up some sludge?
- MAF;
you've changed that so that's unlikely to be the problem (but it's not unknown for a new replacement to be faulty).
- Intake System leaking;
have you checked the vacuum system for leaks (including around the exhaust valves)?
have the inlet manifolds been off, are the gaskets in good condition?
- Exhaust System leaking;
try blocking the exhaust outlets and seeing if the engine note changes.
- Surrey Sam
Louie, try resetting the fault codes and then disconnect the battery for 20 mins.
After that, re-connect the battery and run a fault code check - if any are still there then clear again and if that doesn't get rid of them, there is a deeper problem.
- Firestarter
Thanks Sam.....PM coming bud
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
- Surrey Sam
Fingers crossed mate.
great pics! thanks Toyneg
Great results guys and great pics. Would have popped alone if i was not already committed to something else.
Cant beat a good RR day
- Firestarter
How did the race go Sonny?
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
Another big thanks from me to you and AmD for laying on Sunday. First RS4 event I've been to, so it was good to put some faces to user names.
I was another one that seemed to have "lost" some power since my last RR run - mine made 438ps (so about 430bhp) at mrc last December after having stage 2 manifold & remap, gutted pre cats and CAI fitted. Sunday it only made 413bhp - so I seem to have lost about 17bhp somewhere. I suspect it's variability in rolling roads as the car doesn't feel any slower.
Have to agree with others that generally chasing power increases with these cars is an expensive and largely futile exercise. The one change I would do again is the remap to give full throttle in the first 3 gears and more importantly the more aggressive throttle map in sport mode - that alone subjectively makes the car feel much quicker (even though it obviously makes no difference to actual power!).
David's supercharged car was great - but that mod is just too expensive
2007 B7 RS4 Daytona Avant (the daily driver)
Other current toys: 210bhp Caterham 7 (track toy), 1994 380bhp Escort Cosworth Monte (awaiting engine rebuild), MX5 1.8 Sport (strictly my wife's!)
Gone: Nissan 350z roadster, 205 GTI Mi16, Classic Impreza 2000 Turbo, Nissan Sunny GTiR, Corrado G60, 205 GTI 1.9, Rover Metro Gta (don't ask!), Escort 1.6i cabbie, MG Metro (first car)
- Firestarter
Chaps
The following peeps still need to confirm how they want their prize money paid. Best bet is for me to transfer funds to your respective accounts so please PM me with ya details.
Best Sounding V8 - Mike Fish £60
Favourite Modification - TTS Supercharged RS4 - F11KED (David) £60
Highest BHP for a Tuned RS4 - 577 BHP- F11KED (David) £60
Best Sounding Non V8 - Dave iR8V10 - £40
(I can give to you at the annual Milbrook meet if you want)
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
- Firestarter
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Users browsing this forum: No registered users and 513 guests
