RS4 Wheels
RS4 Wheels
I am hoping to fit some 18" RS4 replicas to my S4 shortly. I spoke to Fontain about lowering the car at the same time (as I understand that if you dont the car may sit a bit high and look a bit odd) and they said that there isnt really room and I should fit them first and have a look.
Anyone have any experience of this - to lower or not to lower, that is the question.
£999 fitted with Avon zz1 tyres - any thoughts?
JonS
2000 Ming Blue Avant, Tanoga Short Shift, Revo, RS4 gearbox (not by choice), RS4 Wheels, Eibach Springs, Forge DVs = Happy Days
I had them with RS4 springs & shocks - the problem is usually that they will rub on the plastic wheel arch liner when cornering hard (very fast open corners). A lot of this depends on the offset of the alloys you are looking at - I had ET30 and had no problems with rubbing, but it needed a 3mm spacer on the front to clear the calipers (supplied & fitted by Fontain BTW). I have seen them much cheaper than £995 - shop around!
Be aware that the 18" RS4 replicas are damn heavy at 29lbs each!
Finally, if your motor has done more than 30k, consider replacing the shocks as well as the springs - Philip Walker can get the H&R setup at reasonable prices. Also consider the H&R ARB's, as they will eliminate virtually all of the understeer.
Nige.
Nige.
Thanks, apparently the wheels (according to Fontain) wont need spacers.
Was thinking on Pilot Sport 2's or Goodyear F1's for tyres.
Is £999 too bad with tyres and fitting and VAT - didnt seem too bad to me.
JonS
Hi Jon
I have RS4 reps from AmD with Goodyear F1 Tyres. Am about to get my 3rd set of tyres now and the F1's have been great. Excellent tyre for all round driving IMO. Dont have any spacers either..
Mik
Mik
2014 Suzuka RS6
So final score from Fontain is:
£1350 incl VAT for RS4 replicas and Goodyear F1s (or £999 for Avon ZZ1s)
£800 incl VAT to fit H& R lowering springs
Or £2000 incl VAT for the lot.
Is it just me, or does that sound a bit on the expensive side?
JonS
I assume thats fitted? Still seems a lot for springs, the H&R coilover kit is £ 725 + vat & fitting I think and a much better solution overall.£800 incl VAT to fit H& R lowering springs
I would get the wheels off ebay too, £ 400 - 500 inc part worn tyres seems to be the going rate. Even if you have to recondition some or all of them, you will still be quids in.
That does seem heavy for a set of RS4 reps......I know Montys do reps without tyres for £420, i think AMD supply the same for £500. I would have thought you could get a decnt set of rubber for £4-500......
Or as DavidT suggested, keep looking on E-bay.
The H&R kit on mine was £710 - it does notsay if this included fitting though.
Users browsing this forum: Majestic-12 [Bot] and 64 guests
