Carbon build up symptoms
Stevec33
Post by Stevec33 » Wed Oct 16, 2013 3:45 pm
What are the noticeable symptoms of carbon build up? I wasnt sure if it was something that makes the car run much worse or if its difficult to tell at all? Ive read various things but thought id ask on here for a definite answer. Cheers
toyneg
Re: Carbon build up symptoms
Post by toyneg » Wed Oct 16, 2013 4:36 pm
I guess it would be hard to tell unless you drive another one that's been cleaned. And see if it feels different to yours. I've had mine a year and only just booked it in for its first decoke on the 28th. I'll let you know if it feels any different.
Get it on a dyno and see if you're down on power or you could do the 3-8k test to see roughly if it's running about right.
Stevec33
Post by Stevec33 » Wed Oct 16, 2013 4:39 pm
Thanks for the reply, i dont really think the car has an issue but i was just curious. What is the 3-8k test? Haven't heard of that before
scaghead
Post by scaghead » Wed Oct 16, 2013 4:45 pm
I have had it carbon cleaned and I could not really tell any difference..do a search of the 3k-8k test...it will tell you how your car is performing to factory figures..
toyneg
Post by toyneg » Wed Oct 16, 2013 4:54 pm
Stevec33 wrote:Thanks for the reply, i dont really think the car has an issue but i was just curious. What is the 3-8k test? Haven't heard of that before
Yeah as Scag said, there's a lot of info on this forum on it, just search and spend sometime going through it.
But basically get a nice clear straight bit of road, put it in 3rd. Bring the revs up slowly and nail it when you hit 3k. Use the onboard lap timer to time how long it takes to get to 8k revs. Do a couple of runs and get an average time. Be careful though as 8k revs in 3rd is over 100mph.
Stevec33
Post by Stevec33 » Wed Oct 16, 2013 7:32 pm
Seems as though a standard car should be 8-8.5 seconds from what ive read, is that about right? Will test it asap
Stevec33
Post by Stevec33 » Wed Oct 16, 2013 7:34 pm
Seems as though a standard car should do it in 8-8.5 secs from what ive read. Is that about right? Will do it asap to check
Post by MikeFish » Wed Oct 16, 2013 7:38 pm
As already stated above, some people say it feels no different, some people say it feels more responsive, some sya quicker 3-8k, others say it's a placbo effect. I think the only clear cut difference is on a dyno, where you should see something close to quoted power after a clean assuming no vacuum issues etc.
Stevec33
Post by Stevec33 » Wed Oct 16, 2013 7:57 pm
Im not a fan of rolling roads, i just think that there is so many variables that its difficult to get realistic figures from them, also the fact that some tuners artifically make your car look like its making more power than it truly is after work has been done on it to make themselves look better, ive had my fingers burnt before. Have a look at this video to see how easy it is to change figures-http://youtu.be/lhaqaninU3s
Stevec33
Post by Stevec33 » Wed Oct 16, 2013 8:07 pm
Link dosent seem to work, if you go on YouTube and type in 'motorsport developments' you will see their video about dyno figure manipulation.
adsgreen
Post by adsgreen » Thu Oct 17, 2013 8:07 am
If you do go for dyno make sure you reset everything with Vag Com.
It's amazing the difference resetting the long fuel trim adjustment makes!
F11KED
Post by F11KED » Thu Oct 17, 2013 12:50 pm
Here's mine before/after...!!
Post by MikeFish » Thu Oct 17, 2013 8:53 pm
F11KED wrote:Here's mine before/after...!!
Wow, they looked much cleaner before!
S4WON
Post by S4WON » Thu Oct 17, 2013 9:30 pm
lol
F11KED
Post by F11KED » Thu Oct 17, 2013 9:58 pm
Stupid iPhone...! It's keeps throwing up a error...!! Put them the wrong way up...!! My bad... You get the idea... ;)
Users browsing this forum: No registered users and 318 guests
