Tricks of the trade ...Anyone
- johneroberts
Just got 4 new wheels and tyres for the GT3, and went put them on myself this morning, only to find the car is too low, or the jack is too high.
Any tricks of the trade for getting over this problem?
I thought about driving the car onto blocks of wood at both axles, but it sounds a bit dodgy.
Otherwise its take the lot down to quick fit and get charged £25 for 20 bolts on and off.
jr
jr
Driving is believing
RS246 Founder
I usually lift the car with the OEM jack, and then use my trolley jack. I also have a square of old tyre that I put on the contact area of the trolley jack to avoid damage, suggest you use a piece of carpet or something.
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Fair wear and tear
Worn them out already?
What kind of driving is that?
MartynC
MartynC
- johneroberts
- johneroberts
philipwalker
- 5th Gear
yep, Blocks of wood are the usual solution.
You can use 8x2 or get some plywood and make laminated 2" risers with a ramp at one end.
For the trolley jack get down to your local sports shop and see if you can buy an ice hockey puck (if not get one off ebay).
These fit in the cup of the trolley jack and work great for lifting the car without marking it in any way.
Cheers,
John.
Cheers,
John.
Too many toys, not enough time
blocks of wood !
I also use two lengths of 8x2 to get onto ramps ( chamferred off for where it meets the road) . I also have a 10" length of 3x3 with a deep groove along it to take the sill flange that I always use at home , just to spread the weight a little better . I also carry a block in the car, after I was caught with a flat and not enough lift on the factory jack to get the unpunctured tyre back on!
I don't think this is a mod
ChrisG
This is what you need!!! http://www.clubphoto.com/_cgi-bin/app.p ... de=sa01_17
2004 X5 4.8is Le Mans Blue
