Just started on Tuesday,very notchy changing gears,especially 1st,2nd,3rd (I think!). Came out of work and couldn't get it into reverse. Eventually it went and again on drive home it wasn't great. Rest of the week it's been absolutely fine! Was just MOT'd and serviced Monday,passed both with flying colours.
Any ideas?
notchy gears
Re: notchy gears
I had the same problem, worse when cold. New clutch, slave cylinder and hose. Now perfect again.
2006 RS4 Cabriolet, Misano Red
2012 A7 SE quattro 245, Impala Beige
Re: notchy gears
Clutch biting point is fine? Plus there's no problem with it now,it's driving and changing fine. When I've had clutches get to the end of their life before they've always gotten progressively worse. Is that not always the case?
Re: notchy gears
Do a search on here for sticky clutches, quite a common problem. My clutch was fine during normal use but developed a sticky pedal during hard use.
Misano Red RS4 B7 Avant
Re: notchy gears
The clutch pedal is fine during any kind of use,was just the gear selection that wasn't right.
Re: notchy gears
These should help:
http://forum.rs246.com/viewtopic.php?f= ... ar#p608016
http://forum.rs246.com/viewtopic.php?f= ... cky+clutch
The sticky clutch thread is just to give you an idea of prices.
Re: notchy gears
Is it difficult to select first and second gears when car is stationary. Or is it affected when in motion also. I only ask as mine is fine when rolling but notchy when selecting whilst still.
Gone and miss very much
B7 RS4 Avant Misano Red, lepsons 2-tone black shadow chrome rims, KW coilovers, AMD Stage-1 with valved non-res milltek catback.
Users browsing this forum: Google Adsense [Bot] and 243 guests
