RS4 BRAKE JUDDER
Re: RS4 BRAKE JUDDER
Same happened to me as well. Wheels were on for 3 weeks after being refurbished then a slight wobble on the wheel at 60mph developed. I cleaned all the hub faces down and was about to get the tracking done when I decided to check the Newly fitted weights. 20grams were missing. Weights replaced and the problem has gone.
Use this site… they only show centres with Hunter equipment IIRCscaghead wrote:It is bloody annoying fella...
P_G how did you find out where one was near you? As on a google search could only find my nearest one if I lived in the states.. Not essex..
http://www.alignmycar.co.uk
- Tile Diver
Yep same here, noticed a small amount of vibration through the wheel at around 60 - 70 mph after a wheel refurb, and change of tyres. Not sure what it is but my first port of call when I get back is to put my winter wheels on the front and see if its still there, if it is then it's more than likely a brake issue, a slightly buckled wheel or a balancing issue.
I'll let you's know how I get on!!
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Cheers Tim..Timster wrote:Use this site… they only show centres with Hunter equipment IIRCscaghead wrote:It is bloody annoying fella...
Took it to a place in wood ford today,they re balanced all four wheels,drove it still had the problem..went on the hunter machine had all the wheels done,drove it problem cured...and also driven it back 15 miles to home and the road I drove back on was mainly 50 ish mph all the way still as good as gold..so hopefully problem sorted..(touchwood)..
ooh that's good news! hopefully I can have a simililar story - just need to get a chance to take it somewhere with a Hunter machine
- Firestarter
AmD have one Graham!
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Don't think it's the same hunter machine fella..i know they have the hunter four wheel drive alignment kit..the thing they used on mine was the gsp 9700.Firestarter wrote:AmD have one Graham!
The fella did say it could be a number of things,so the gsp 9700 is not a cure for everything..
Found somewhere not to far with the GSP9700 - £18 a wheel, has to be worth a shot.scaghead wrote:Don't think it's the same hunter machine fella..i know they have the hunter four wheel drive alignment kit..the thing they used on mine was the gsp 9700.Firestarter wrote:AmD have one Graham!
Fingers crossed looks like that hunter machine has done the trick so many thanks P_G for the suggestion
- RossDagley
- Top Gear
New discs and pagid OEM pads fitted <1500 miles ago by Hitchin Audi (parts supplied by me - from ECP as part of the deal if anyone remembers).
Regretfully saying now have severe judder slowing gradually from high speed (I mean 130mph downwards for example, but just slowing, not trying to chew dash...)
Only other thing that complicates things is I've had a wheel refurb (by a local company, sprayed not powder coated) and have fitted H&R 8mm spacers basically at the same time as fitting the brakes.
I can't feel any lips or bumps etc on the front discs, and they visually look ok. Is it worth having that guy Marcus (skimmydiscs) as I'm only 20 miles from him, or better to get a hunter balance or...?
Bit gutted tbh. That lot cost a fortune lol.
Previously:
Previously:
I would give Marcus a call as he's local, knows his stuff and it's probably worth checking these things in detail.
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
HI RossDagley
Did you get your brakes fixed?
I had exactly the same issue as yourself and Marcus fixed the problem straight away. That was 12 months ago and no problem since
Currently - nothing!
Past Cars:
Misano Red B7 RS4 Saloon with Black Optics, Milltek Non-Res Valved with black tips, lowered 20mm with H&R springs, stock DRC suspension
Phantom Black S4 B7
Audi A8 3.0TDi
Past Cars:
Phantom Black S4 B7
Audi A8 3.0TDi
- RossDagley
- Top Gear
hi!AudiSingh wrote:HI RossDagley
I've had MRC check the hubs and wheel face, and there was nothing really to find - they made sure the surfaces were clean but other than that, there was no improvement. Then I mentioned to Doug that I was running the EuroCarParts "oem" pads and he almost slapped me. He recommended I change immediately to Ferodo Premiere pads (still very low cost, but much better apparently).
I bought online last week and drilled all the holes in the discs clean (there was a LOT of pad material). Then I fitted the new pads.
I didn't have much time, but bedded the pads in as best as I could on Wednesday last week. Thursday I drove the 700 miles from my house to the Nurburgring where I've spent the last 4 days, returning yesterday. By the end of the trip there, I experienced no more judder at all. I did 7 laps of the 'ring (3 back to back) and never experienced anything other than perfect breaking. No judder, no fade, nothing. Then drove home yesterday, again, with perfect brakes.
The pagid pads I was recommended by Doug @ MRC have completely cured my judder for sure. I think I will need another set of pads soon (I have another 'ring trip next month) so may go for something better again, but I think the lesson here is nasty cheap pads = expensive option. I was very lucky not to have ruined a brand new set of disks with those cheap EuroCarParts shitty pads.
Here are the pads I'm currently using:
http://www.ebay.co.uk/itm/161259193413
Previously:
Previously:
I have a ring trip next month so I like what your saying but you mentioned ferodo and pagid pads in your post can you clarify please
Users browsing this forum: No registered users and 343 guests
