RS4 Spark Plug Change - How To Guide
Surrey Sam
Post by Surrey Sam » Mon Sep 09, 2013 6:38 pm
***best viewed on a computer/laptop due to photo size***
Right I did a Plug Change on my car the other day and thought I’d document the process to help anyone who was thinking of doing this job themselves. Audi recommend that the plugs are replaced every 6 years/60,000 miles - mine were approaching 6 years old and had covered 42k miles, so I felt they needed doing and I wasn't wrong:
The tools I used for this job were:
Phillips screwdriver
T30 – Torx bit
T20 – Torx bit
A driver/ratchet for the Torx bits
7mm socket (for jubilee clip, so flat blade screwdriver could be used)
¼” drive ratchet and extension bar
Spark Plug socket
½” drive ratchet and two extension bars
Torque Wrench
Ok first up, I accept no responsibility for anyone who may follow this and damage any parts/engine or indeed themselves. Overall it’s not a hard job to do, but there are points where it can be a little fiddly. If you’re really not sure about carrying this procedure out, then pay a professional to do the work for you.
However, there may be a few spanner twirlers around whom hopefully find this to be helpful.
Step 1
Removal of the plastic cover on the right hand side of the engine bay, this covers the PAS reservoir and the washer fluid reservoir.
Take the T30 torx bit and remove the screw located at the front, this winds into a clip located within the front slam panel. Once the screw is removed you can lift up the front part of the plastic cover and it will pull off a rubber locator next to the coolant reservoir.
Step 2
Take Phillips screwdriver and remove the screw located on front right hand side of coolant reservoir. The official Audi documentation will then have you clamping both coolant hoses and draining the tank down. However, with a little patience further on, it isn’t necessary to do that; there’s enough slack and movement in the system, to wiggle/manoeuvre stuff around it. So I elected to just remove the screw; the choice is yours.
Step 3
Remove the Oil Dip Stick as it will be in the way. Once removed, I like to put a piece of coloured tape over the top to ensure that no foreign body drops down the tube and into the sump.
Step 4
Take the T20 torx bit and remove both screws that hold the coil pack wiring loom onto the red valve cover.
Step 5
Now for the first fiddly bit – Unclipping the coil pack connectors. There is a couple of movements required together in order to undo these.
1) Press the plastic bit I have arrowed downwards firmly
2) Whilst doing the above, push the clip into coil further until you hear a feint but audible click.
3) Once you hear the click, you can then wiggle the connector off from the coil.
4) Start on the one nearest the oil filler cap first to practise as the rearmost one is harder to get onto.
5) If you are struggling with this step then walk away and get yourself a drink, come back to it 5 minutes later - a screw driver does not help here and will only serve in breaking the plastic clip.
Step 6
Removing the coil packs. Audi have a special tool for doing this but it can be done by hand. I squeezed my fingers under the coil pack edge as detailed in the picture (use both hands though) and then wiggle and pull up at the same time. Do this for all four coil packs with the last on being rotated 90 degrees whilst lifting the coolant reservoir as indicated in the second picture. On the underside of the coolant reservoir is a sensor; it didn’t get in my way, but for those with big hands just be mindful of its position.
Step 7
At this point with the spark plugs still fitted I chose to clean the valve cover as the coil packs can hide dirt. The step is certainly not necessary but I like my engine to look clean. The product I use is Bilt Hambers Surfex HD diluted with distilled water at a ratio of 1:5; this I spritz on, agitate with a soft bristled detailing brush and wipe off with a microfiber cloth.
Step 8
Spark Plug Removal. Take the ½” drive ratchet, spark plug socket and the extension bar, undo the plugs in an anti-clockwise direction and lift out. The rear ones were removed in much the same way as the coil packs, by lifting the coolant reservoir and adding a second extension bar as shown in the picture.
Step 9
Take the new plugs and screw them back in clockwise, I like to do this by hand without the ratchet until I can no longer turn them. Set the torque wrench to 25nm and tighten them all up, then adjust the torque wrench to the final recommended setting of 30nm and tighten all four again.
Step 10
Refit everything you have just removed in steps 1-6 and have a half time break. In my case, cup of Coffee and a slice of homemade Coffee cake. Yum.
Step 11
Split the air inlet feed. Use both hands and just pull back the corrugated section; it should separate from the front part fairly easily. When it comes to refitting this part later on, pay particular attention to getting all the clips both top and bottom locking in right, before pushing it back together.
Step 12
Using the Phillips screwdriver, unscrew the two screws on the front section of the air inlet feed, these are indicated in the picture. The plastic component is then free to withdraw from the slam panel housing.
Step 13
There is a hose which is clipped to the top of the airbox, opposite the MAF sensor; this can be pulled off with relative ease leaving the clip still secured to the hose.
Step 14
Secondary Air Pump inlet hose. This has two clips which you press in together which release the hose to be pulled from the airbox assembly.
Step 15
Unplug Mass Air Flow connector. This connector works exactly the same way as the ones that plug into the coil packs. Refer back to step 5 to re-familiarise yourself if not sure.
Step 16
90mm flexible air inlet hose. Take the 7mm socket and loosen the jubilee clip, this will enable you to slide the hose from the Airbox lid/MAF housing.
Step 17
Airbox lid. There are finally two Phillips screws that need to be removed as arrowed in the picture. Once done the housing lid will lift off and out, leaving you sufficient access space to carry out the rest of the work.
Step 18
With everything needing removal completed, you can carry out steps 4-9 as per the previous cylinder block completed earlier.
Step 19.
Once all the new plugs have been fitted and torqued correctly, you can re-install the previous parts that were removed in Steps 11-17.
When finished, the engine bay should look like this. Job done.
The_Coat
Re: RS4 Spark Plug Change - How To Guide
Post by The_Coat » Mon Sep 09, 2013 6:47 pm
Great write up, thanks for posing this up.
The cake also looks spot on!! :)
RS4 Avant - Misano Red
Batfinnk
Post by Batfinnk » Mon Sep 09, 2013 6:56 pm
Fantastic write up. One thing I would add is that of your spark plug socket hasn't got the rubber insert to hold the plugs use a pair of bent nose pliers to remove the old plugs and slowly slide the new plugs into the chambers otherwise if you just drop them in you risk screwing up the gap on them :)
Previous car: 2005 S4 B7.
The_Coat
Post by The_Coat » Mon Sep 09, 2013 7:07 pm
Am I right in thinking the plugs can go in straight out of the box and the gap is already correctly set?
Was looking on the NKG website and that's how it read, can anyone confirm?
Batfinnk
Post by Batfinnk » Mon Sep 09, 2013 7:09 pm
Not sure about NGK's but I put the Bosch quad tips in mine so no adjustment needed on them.
Surrey Sam
Post by Surrey Sam » Mon Sep 09, 2013 7:27 pm
Thanks for the comments guy's.
The_Coat - Cake was good, although I was being very well behaved with portion size.
Batfinnk - Good point about the plug socket rubber.
With regards to the gap, I could find no definitive size. NGK say that theirs are pre gapped for the RS4 application. However I was supplied the Bosch ones because they superseded the NGK item, due to some NGK's suffering from broken cores according to my dealer.
The old NGK's I removed measured 0.9mm and the new Bosch one were measured at 0.7mm. After fitment my engine gained greater urgency to rev out past 5000rpm, I had the kick previously, but it's now more pronounced. I just attribute that to new plugs though.
Tile Diver
Post by Tile Diver » Mon Sep 09, 2013 7:39 pm
Excellent write up man!!! However, it looks a bloody nightmare, I think I'll leave it to the pro's as I've got a tendency to over tighten and snap everything I touch!!!
Thanks for taking the time to take the photos and post it up, I changed my discs and pads following Sonny's guide and it was great!!! :beerchug:
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
MB2
Post by MB2 » Mon Sep 09, 2013 7:51 pm
Great write up, thanks for taking the trouble to take all the photos too. I would add that removing the expansion bottle is fairly easy as can simply be syphoned empty and then once is removed can suck a little bit out of the hoses or bung them - I did a guide on changing the bottles over to make the engine bay look newer so could be worth doing at the same time, likewise an ITG filteron the other side.
I also used to use a bit of hosepipe to lower the plugs into motorbikes but haven't changed the plugs in the RS4 so don't know if that fits, do agree to locating them by hand though if at all possible !
scaghead
Post by scaghead » Mon Sep 09, 2013 8:10 pm
Excellent write up fella..well done.
jonicox
Post by jonicox » Mon Sep 09, 2013 9:06 pm
Superb write up and what an absurdly clean engine bay!
8L S3 with stage 2 (gone)
B7 A4 DTM (gone)
B7 RS4 (Miltek Res Valved, 100 cell cats, Ceramics, Carbon cleaned) gone
C7 RS6 Panther, carbon pack,
Firestarter
Post by Firestarter » Mon Sep 09, 2013 9:15 pm
Nice one Sam. Excellent job there mate and thank you for taking the time to produce a concise and easy to understand procedure.
Prompted me to check my service history as mine is at 59k. Amazingly the car was serviced at 57.5k and is a June 2006 build, however no plugs were changed.....Dam Audi Steelers!! A job for the weekend me thinks!
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT :-)
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre :-)
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Post by Ian_C » Mon Sep 09, 2013 9:45 pm
a) great write up
b) lovely clean engine bay
c) I've got that exact same mug!
Batfinnk
Post by Batfinnk » Mon Sep 09, 2013 9:50 pm
One other thing I just thought of from when I did mine. If your having trouble getting the coilpack plugs or any of the other plugs that use that type of lock I used a little flat blade electrical type screwdriver and just inserted the blade in the bottom end of the clip,ie: the opposite end to where you push down and without any force it will release the clip if it is tight but don't use this to push it off. Pull the plug as instructed above.
ArthurPE
Post by ArthurPE » Tue Sep 10, 2013 8:13 pm
nice
RS4GCI
Post by RS4GCI » Mon Sep 26, 2016 3:13 pm
Just used this guide to change my plugs and it was very useful - thank you.
One little tip that may help others is that I struggled to get the coil packs out that were nearest the header tank as it was an awkward spot, so used VERY light leverage with a lever bar with cloth underneath so as not to damage the valve cover. I must stress it was only very light leverage and it worked a treat for the awkward buggers under the header tank.
Panther Black RS4 B8
Users browsing this forum: No registered users and 1236 guests
