Really sorry if this has already been explained. I'm having problems with my Drc so I've ordered a set of H&R coilovers. Is this a simple change over or do I need to have the ecu adjusted or buy some extra kit?
Thanks Gareth
Drc to coilovers.
- PetrolDave
Re: Drc to coilovers.
DRC is 100% mechanical, there is no ECUGarethtdi100 wrote:Is this a simple change over or do I need to have the ecu adjusted or buy some extra kit?
Garethtdi100
Thanks for your reply. I take it you just disconnect the pipes from the shock and forget about them?
- PetrolDave
Someone who has replaced DRC will have to answer that, I'm still running DRC.Garethtdi100 wrote:I take it you just disconnect the pipes from the shock and forget about them?
I just love the assumption that DRC is connected to the (electronic) diagnostics - you're not the first person to make that assumption (and won't be the last I suspect).
Garethtdi100
I just wandered as I seen on a dealers website about a "DRC cancel kit". My mechanic is working at the car now so ill update this shortly. This is the site i seen it on. http://www.awesomegti.com/car/audi/rs4b ... pe-qb6-4wd
Garethtdi100 wrote:Thanks for your reply. I take it you just disconnect the pipes from the shock and forget about them?
Exactly that, leave it all intact just disconnect the shocks from the system and leave in situ..
B8 RS4 in the fastest colour
Users browsing this forum: Bing [Bot] and 2046 guests
