ceramic rear brakes
RS6chris!
Re: ceramic rear brakes
Post by RS6chris! » Thu Aug 29, 2013 9:31 pm
Never mind that...prism silver looks awesome!!
Not a fan of silver but love the way it shows the shapes of the B8?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Rick_RS4
Post by Rick_RS4 » Thu Aug 29, 2013 10:48 pm
does the car really warrant 11 grands worth of brakes where you most probably wont use to their full potential
coffey555
Post by coffey555 » Fri Aug 30, 2013 12:32 pm
leadfoot wrote:What was the offset on the OEM 18's... thinking about a track tire, as an 18 would be cheaper, better and more options...
ET24
Misano Red RS4 B7 Avant
Cuppa
Post by Cuppa » Fri Aug 30, 2013 1:27 pm
I have the rear S7 ceramics on mine (to get the electronic parking brake functionality). No idea if they work for your application, but it's another option to investigate.
S5 Supercharged V8 Coupe - Meteor Grey / Magma
TTS Supercharger (601PS / 675Nm) | Capristo Valved Exhaust | KW DDC Coilovers | JHM Short-Throw Shifter | HRE P104 21x10.5" + PSS
Ceramic Brakes (R8 GT Front / S7 Rear) | RS5 bootlid | Rieger S5 bumper | Rieger Sideskirts | RS5 grille | SPC adjustable UCA
H&R ARB kit | custom stereo & more |
Fuelly | >> click for build thread << | Facebook Page
jimbo1234567
Post by jimbo1234567 » Fri Aug 30, 2013 2:33 pm
Rick_RS4 wrote:does the car really warrant 11 grands worth of brakes where you most probably wont use to their full potential
im around the 700hp mark on my b5 and i do track it now and again, its a heavy car and does take a bit of stopping, besides rusty discs are doing my head in. :biggrin2:
jimbo1234567
Post by jimbo1234567 » Fri Aug 30, 2013 2:36 pm
Cuppa wrote:I have the rear S7 ceramics on mine (to get the electronic parking brake functionality). No idea if they work for your application, but it's another option to investigate.
its your damn fault im on one with this, those red gt calipers look ace, i had a good look at them at aitp. :bigwave:
think im going to look for a full r8 gt setup for mine and maybe get smaller pistons fitted to the rear calipers. :biggrin3:
Surrey Sam
Post by Surrey Sam » Fri Aug 30, 2013 2:42 pm
its your damn fault im on one with this, those red gt calipers look ace.
x2 :nodder:
adsgreen
Post by adsgreen » Fri Aug 30, 2013 2:49 pm
coffey555 wrote:Fit a brake bias adjuster?
Probably not as straightforward as you think - the brakes are 4 channel so each wheel has it's own dedicated line back to the brake controller. The force going to each one is controlled from here so limited places to install a bias adjuster.
adsgreen
Post by adsgreen » Fri Aug 30, 2013 3:03 pm
coffey555 wrote:Well that solves that one then. I guess you would want the bigger wheels anyway given the extra braking performance available.
Bigger wheels actually hurt braking performance. In general a wheel rim is heavier than the equivalent volume taken up with air and rubber. So the bigger the wheel the more mass. It also doesn't help that the mass is being moved further and further out from the wheel centre so the rotational inertia is also going up.
I remember talking to an engineer where they calculated the best wheel size for a particular sports car was 14" but the styling department simply refused.
Anyway - the tyre is exactly the same size regardless:
255/35 19R -> 661mm diameter
255/40 18R -> 661mm diameter
So in principal exactly the same amount of rubber will be on the road (a bit simplistic though).
I wonder if anyone on here is running 18's on their car and how it affects the ride quality?
Probably rides better as the larger profile would soak up the smaller bumps whilst the lower wheel mass would ever so slightly be able to move react faster to road surfaces.
coffey555
Post by coffey555 » Fri Aug 30, 2013 4:16 pm
Interesting, I wrongly assumed that the 18's would have a 235 section resulting in a smaller contact patch with the road but you are quite correct, they are indeed 255.
I had not considered the extra inertia of the bigger rim either.
So if I was to switch to 18's for winter use, theoretically I could adjust the compression and rebound settings to take into account the reduction in unsprung mass?
adsgreen
Post by adsgreen » Fri Aug 30, 2013 5:10 pm
Yes - but in not sure on the actual weight difference. Be interesting to find out.
Rick_RS4
Post by Rick_RS4 » Fri Aug 30, 2013 10:16 pm
i meant on the b7, no beef with yours at 700 bhp
Cuppa
Post by Cuppa » Sat Aug 31, 2013 8:15 am
:biggrin3:
Users browsing this forum: Google [Bot] and 382 guests
