Avus Avant 2008 sloooow build
Re: Avus Avant 2008 should I?....So i did!
One more thing, I find as you peal and get to the edge of the badge you pull the dip sheet away from the badge and gently
- TonyHayers
- 5th Gear
Interesting. I'm getting tempted to actually give it a try on my silver window trims.
06 Phantom Black Saloon:
^ GONE
^ GONE
If u do, buy the cleaner too. Helps keep the surface free from oil or waxes that build up from washing. That will help give a better finish
Me too. Anybody any idea which plastidip coulour is closest to OEM silver trim?TonyHayers wrote:Interesting. I'm getting tempted to actually give it a try on my silver window trims.
They don't make a silver yet!
They do a "true metallics anthracite" though which is almost the same as 8AU colour code for the titanium spec mirrors and wheels
Before
Next up
After
Next up
seriously contemplating this .... can you show a close up of the finish please? Any plans to do the window trims and roof rails?
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit
Roof rails were painted black before I got the car and the wheels were Ti, so I am just completing the black optics
Rear badge done but its not perfect so will re do it
I went for matt finish so there is some texture but you can get gloss look with a glossifierRS4pete wrote:seriously contemplating this .... can you show a close up of the finish please? Any plans to do the window trims and roof rails?
Here is a decent Pre-peal pic
and the window trims?
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit
Haven't done the window trim yet, I am getting comfortable with the small bits, but I recon they are next!
It's honestly so easy, just lots of light coats and allow to dry between each coat! So it takes time but this gives a smoother finish and when u build up layers, the pealing process is a lot easier.
Can't say this enough, but go check out Fonzi on YouTube at dipyourcar
Did this today too
Did this today too
We should start the 'Faux Ti Avus Silver Owners' Club '
FTASOC lol
How about the rear rings? And did you consider doing the R entirely black?
You could easily 'saw' the RS 4 and rings off with dental floss and then have better Co tool when spraying them. Then just reapply with auto badge adhesive from 3m.
FTASOC lol
Think i may have to do that Saki with the RS badge to get the red block perfect.
So i have done the rear rings now, the RS badge (thinking of doing the flank ones too) and the front grill surround.
Looking at the mirror removal may try that next and pull it off if it looks sh1t
Ive done the front grille same as you (our pictures look very similar funny enough...I think we discussed this in the b7 RS4 pic thread). I still want to do:hlbeckley wrote:Think i may have to do that Saki with the RS badge to get the red block perfect.
a) rear rings
b) window trim
I will not bother with the mirror caps. For the window trim, I can't see myself being patient enough to do it well, so I will likely just go to a vinyl wrap company and have them do it. A place here has offered to do it for $200 which seems a bit expensive, but hopefully a few of us can band together and get a better deal. I wouldn't vinyl wrap it on my own. It's apparently tough to get the corners right.
plastidip would be pretty easy on the window trim but as I said tough to block off the entire car and not go crazy lol
after 800 kms...
