Must be tight! B6 S4 345mm discs are snug as a bug in a rug under B5 S4 17s - I have the thickness of a wheel weight clearance [on my B5 winters] - so I'd have thought the max that would be 345+25 = 370 mm under 18sjimbo1234567 wrote:18 " wheels will fit over 380mm discs.
ceramic rear brakes
Re: ceramic rear brakes
What about S8 rear ceramics, could they work?
The B7 RS4 was available from new with 18's as an option so the standard brakes will fit.
If the ceramics have a larger heat shield then that might be a problem.....
Angle grinder and £6000 brakes a set too far?
Misano Red RS4 B7 Avant
- PetrolDave
If you specified the front ceramics option, you got 19" wheels as part of the package - so Audi didn't think that 18" wheels would fit over the front ceramics.coffey555 wrote:The B7 RS4 was available from new with 18's as an option so the standard brakes will fit.
As it says in the hardback RS4 book: "note: only in combination with 19-inch wheels".
jimbo1234567
- 5th Gear
never knew that 18,s were an option onthe b7, dont think ive ever seen any.
665 bhp + 586 lbft...
Well that solves that one then. I guess you would want the bigger wheels anyway given the extra braking performance available.
I wonder if anyone on here is running 18's on their car and how it affects the ride quality?
There was a blue Avant on autotrader a while back but that car was the only one I have seen.
- PetrolDave
18" were standard with 19" as the option in most countries, the UK was one of the few countries where 19" were standard with 18" as the option.jimbo1234567 wrote:never knew that 18,s were an option onthe b7, dont think ive ever seen any.
I run team dynamics pro race 1.2 18" wheels over my 380mm ceramics with no problems
Unit 20
0151 3366888
0151 3366888
What was the offset on the OEM 18's... thinking about a track tire, as an 18 would be cheaper, better and more options...
Rare! Super stealthy, came in both 8.5 and 7.5" fitment, the later being offered on the continent as the winter option.jimbo1234567 wrote:never knew that 18,s were an option onthe b7, dont think ive ever seen any.
Almost looks like a Lotus Carlton! If the spoke were angled slightly it'd be not far off!
Doesn't the B8 RS4 and the RS5 come with ceramic rears as an option? Those would obviously be a good match but you'd be lucky to find a cheap set.
I don't think so, the rears of the ceramic spec cars look plain steel
No rear ceramic option for rs5 or b8 rs4
I repeat...iR8V10 wrote:What about S8 rear ceramics, could they work?
Users browsing this forum: No registered users and 327 guests
