ceramic rear brakes
jimbo1234567
ceramic rear brakes
Post by jimbo1234567 » Thu Aug 29, 2013 10:23 am
were ceramics an option from the factory on the rear this car ? :biggrin2:
coffey555
Re: ceramic rear brakes
Post by coffey555 » Thu Aug 29, 2013 10:25 am
Only the fronts I believe.
Misano Red RS4 B7 Avant
jimbo1234567
Post by jimbo1234567 » Thu Aug 29, 2013 10:49 am
so is there another option the get the back end looking the same ?
Gumball0r
Post by Gumball0r » Thu Aug 29, 2013 12:12 pm
I believe the ceramic rears from the R8 will fit (might need some adjusting). Are you fitting them to a B5?
jimbo1234567
Post by jimbo1234567 » Thu Aug 29, 2013 4:18 pm
yes ive currently got the ap setup on my b5 with 362 front discs and 6 pot calipers and on the back they are 343 mm discs with a 4 pot caliper and a seperate handbrake caliper, i know movit do a full kit but i want to be able to use my 18 inch track wheels and they are ridiculasly expensive. :biggrin2:
Surrey Sam
Post by Surrey Sam » Thu Aug 29, 2013 4:32 pm
Whilst the R8 rears would fit under 18" wheels the front ceramic option comes in at a larger 380x38 and would then require 19" wheels, this is for both B7 and R8 from what I've been looking into.
jimbo1234567
Post by jimbo1234567 » Thu Aug 29, 2013 4:41 pm
18 " wheels will fit over 380mm discs. :bigwave:
you may well be able to fit the r8 rear setup physically but the pistons are sized for a rear engined car and will be far too powerful for a front engined car. :biggrin2:
coffey555
Post by coffey555 » Thu Aug 29, 2013 4:44 pm
Fit a brake bias adjuster?
adsgreen
Post by adsgreen » Thu Aug 29, 2013 4:44 pm
jimbo1234567 wrote:18 " wheels will fit over 380mm discs. :bigwave:
+1 was about to say the balance will be shot to hell.
Given that you have to tweak the brake ecu to let it know it has ceramics I would suspect that this would not cope to well with ceramics on the rear as it'll assume that they are conventional discs.
jimbo1234567
Post by jimbo1234567 » Thu Aug 29, 2013 4:48 pm
on the b5 i can see that there will be a coding option for ceramics but as long as the piston sizes are balanced i cant see there being a problem. on the ap,s the pistons in the rear calipers are tiny which obviously stops the rear end getting too much stopping power. :nogarors4:
DAC
Post by DAC » Thu Aug 29, 2013 4:49 pm
RS4 Phantom Black Saloon
Post by bam_bam » Thu Aug 29, 2013 4:55 pm
£5,600 :shock:
DAC
Post by DAC » Thu Aug 29, 2013 4:58 pm
That's what I thought
Post by MikeFish » Thu Aug 29, 2013 5:29 pm
bam_bam wrote:£5,600 :shock:
And that is just for the rears!!!!
Oddly, she has the fronts for the same price though.
Surrey Sam
Post by Surrey Sam » Thu Aug 29, 2013 5:32 pm
I might be wrong but I seem to remember reading that the disc isn't the problem, it was the larger heatshields used on the ceramic option.
Users browsing this forum: Google Adsense [Bot] and 313 guests
