losing all total grip in the wet b5 s4
Hi all i have some some seriously scary simple corner and roundabout scaryiness in my my bs s4 avant where at normal speeds i iam turning in and losing all traction ..almost like iam driving on ice leftb and side, it breaks away without warning ..is it a tyre issue?? it is evident when entering a corner / roundaout off throttle is this normal..
Re: losing all total grip in the wet b5 s4
What tyres are you running?
Teutonic_Tamer
^^^ x2chunky79 wrote:What tyres are you running?
Also, what pressures are they?
Are they in at best at least axle-matched pairs?
Are they the correct load and speed index?
Finally, how old are the tyres? They should have a four-digit code which determines when the tyres were manufactured - something like 5109 - the first two digits are the week, the second two are the year - so 5109 would mean they were made the 51st week of 2009. If they are older than 6 years old - bin them.
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
thanks for the replies the dates are ok but i have a bridgestone potenza front left ..dunlop sportmaxx front right and a pair of Event ..made in china on the back ..all the treads are within limits ..do
hould at least replace the fronts as a matched pair ..if so what make /model?
pressures by the way 36psi in the fronts and 34psi on the bck
Is this a joke? Gotta be.
It's a bit like asking why one has a STD results list as long as a Tesco receipt following a week long stag do in Amsterdam.....
no iam being totally serious . i cannot find any decent info ..so thats why iam asking on here
Your tyres are <beep> is the answer your after
Seriously, remove the ditch finders and stick a set of decent rubber on there, Goodyear Eagle Asymmetric 2 definitely being the forum choice
Mine came with different tyre model / tread Dunlops front and rear, never felt right. Asymmetric 2s TRANSFORMED the car and turned it into the car I'd always wanted it to be
God knows what yours feels like with Chinas worst on the back!
Dads now running Goodyears on his Sportback, same 225/45/17 as the B5 S4, they wear well across the tread, firm sidewalls, shoulders don't seem to wear too badly, keep an eye on tyre pressures
http://camskill.co.uk/m54b0s16p109613/G ... se%3A_69dB
thanks very much ..i will get some this weekend and keep you posted
Spaceman_RS4
Even if on a budget stick a set of verde steins on it bud.
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
so the eagles are on £97 a corner at Wembley Tyres and feel much better ..just wait for some wet roads ..abs ecu ..to tackle next ..reading the owners manual it states that the rear under heavy braking can break away sideways ..great!
Spaceman_RS4
Sounds like fun it's a bitch to get my rs4 to power slide unless its snowy or really greasy
