Outside Temperature reding is wrong
5.2 V10 40v Naturally Aspirated - 429bhp
Post by 801 » Thu Aug 22, 2013 6:59 pm
What could be causing this? Outside temperature is ok for a while then goes much higher than actual outside temperature.
Blockage somewhere?
Where is the thermometer?
adsgreen
Re: Outside Temperature reding is wrong
Post by adsgreen » Thu Aug 22, 2013 7:42 pm
How higher is "much higher"?
What are you using to compare what it says with what you think it is?
Trups
Trader (Expired)
Post by Trups » Thu Aug 22, 2013 8:41 pm
yes I get this on my C6 RS6. yday it was not hotter than 21 here as per the reading on my polo.
i swapped cars and went to do a tip run in the RS6 and pump up tyres and it was showing 32. i think its the heat from the engine that's doing this lol
801
Post by 801 » Fri Aug 23, 2013 3:14 pm
Unless the met office are not telling us the whole truth I donor believe, driving along the M3, even with temperatures due to be late 20s the outside temperature reads 45-50 degrees.
Ditto heading into the Alps last Easter it was warmer than usual but the reading was 25-30 degrees. Not possible given the amount of snow on the ground.
It's ok for a while but then just keeps getting higher and higher. Never gets ridiculous but clearly it's not working as one would expect. Bit of a pain in cold weather.
It's a 57 plate S6 Avant by the way.
Trups
Trader (Expired)
Post by Trups » Fri Aug 23, 2013 3:28 pm
maybe get a new sensor to see if it could be that?
adsgreen
Post by adsgreen » Fri Aug 23, 2013 7:25 pm
Ok, yes that does sound quite out.
Remember the met office quote the temperature in the shade so the "actual" might really be a lot higher if in the sun (but not by that much).
ahoooga
Post by ahoooga » Sun Aug 25, 2013 11:08 pm
Common problem on a C5 , so i guess its probably the same on a C6.
C6 ambient temp sensor G17 is same place as on the C5 , sensor is behind the front bumper.
Its a bumper off job to change it.
Item No 10 in the picture
Return to “S6 (C6 Typ 4F) 2006-2011”
