RS4 BRAKE JUDDER
Re: RS4 BRAKE JUDDER
Thanks to everyone for the excellent information here.
I bought my car in Germany, brakes had terrible judder. Insisted on replacement and dealer fitted new discs and pads. Collected the car, drove back to Nice, slight judder appeared from 60kph down.
After reading this I am going to give it a calculated, heavy braking session to attempt to clear it.
It makes the most sense regarding deposits and buildup, and seems to be in line with what most people are saying.
Thanks again,
Daniel
Thanks again,
Daniel
Now: 2007 Daytona RS4 Avant
Passed On: 2003 Mugello RS6 Sedan
Well, I've cured mine totally - Even though I had a complete set of discs and pads all round about 4 months ago, I developed really bad brake judder. A track day just made things worse. So here's something for others to try ....
1) Ensure all the vent holes on all the discs are clear - I used a neighbours compressor to clear mine out and the also the cleared the excess dust from all four calpers.
2) Stop using the handbrake after a long trip or where your discs are hot when parking you car up. I just leave my car in reverse or second now.
The combination of the above has completely cured my judder - I'd like to think that (1) had a lot to do with it but I can't prove it. Certainly (2) has made a massive difference in my case.
I had to re-read that about 4 times before I understood what you meant Kev. I initially thought you were suggesting in point 2 that we should use the handbrake to stop!!! The bit about leaving it in gear didn't match this crazy and dangerous solution of yours so I kept re-reading it until I actually realised you meant do no use the handbrake when hot! I'm a wally!
Text edited for Mike
Abused mine again tonight, bish bosh no more break judder
Slight whiplash tho
lol
- Firestarter
+1
Had a session at the Horton Test track (KEVIN will know where this is) before Mr T went to AmD and had slight judder before, however once given a good spanking no more judder.........apart from me trying not to say KKKKKKKKKKKKKEVIN
CheeRS
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
SVM 102mm decated zorst with Black Tips....ITS LOUD & HOT
1050cc Asnu injectors,
SVM 80mm MAF intakes
K&N High Flow Filters
SVM Custom EcuTek map (Thanks John!!)
and a shitload of Carbon Fibre
B7 RS4 (Mr T) - Gone but never forgotten and still in Surrey
Louie
R35 GT-R
The Dark Destroyer
- ダークデストロイヤー
SVM650R stage 4.25
Decided to clear out my fronts today also, interestingly the front drilled holes align both sides of the disc, the rears don't? The backside of my fronts were clogged solid, I also reinstated the taper on the holes I could see. Can't wait to try them out
Had my wheels refurbed a couple of months ago,and have noticed I am getting steering wheel judder at around 50/60 mph..I am presuming my problem is not related to brake judder as mine is not happening directly under braking?my logic is it was not there before the wheel refurb so I am thinking I have a slightly uneven finish on the inner side of the alloy/ hub?..thing I can't work out is the steering wheel only judders at 50/60 mph can't feel anything through the wheel below and above them speeds...any idea fellas would be appreciated..
Get your wheels on a Hunter GSP9700 rolling road balancer and it'll show whether your wheels are mishapen and go about dynamincally balancing them.
scaghead, that's weird, I have exactly the same issue! Had my wheels refurbed and since just can't cure the problem, had the wheels swapped, balanced 3 times, 4 new tyres, it's so annoying eh!? Would welcome any ideas anyone has...scaghead wrote:Had my wheels refurbed a couple of months ago,and have noticed I am getting steering wheel judder at around 50/60 mph..I am presuming my problem is not related to brake judder as mine is not happening directly under braking?my logic is it was not there before the wheel refurb so I am thinking I have a slightly uneven finish on the inner side of the alloy/ hub?..thing I can't work out is the steering wheel only judders at 50/60 mph can't feel anything through the wheel below and above them speeds...any idea fellas would be appreciated..
It is bloody annoying fella...
P_G how did you find out where one was near you? As on a google search could only find my nearest one if I lived in the states.. Not essex..
- Surrey Sam
TPMS sensors perhaps?
In the refurbishment process they may have been over tightened causing damage to the thread and have now come a little loose.
def worth looking at Sam, it's weird because I have wheel wobble/vibration but only between 60 and 80. will try finding somewhere with that hunter wheel balancer as well, thanks PGSurrey Sam wrote:TPMS sensors perhaps?
Have you given the wheel hub a good clean? If it only happens at a certain speed and then oes away as the speed increases it defo sounds like a balancing issue. If the wheels are balanced then maybe they just aren't sitting flat against the hub. I know you said you checked the wheels but it could also be the hub.
could just be a <beep> balancing job by the people who did the refurb? or maybe one of the wheel weights has fell off?.
this happened to me shortly after i refurbed my wheels, i started to get a bit of vibration in the steering wheel around 70-80mph.
so took it back to the place that balanced my wheels and sure enough one 15g wheel weight had fell off!, re balanced the wheel added the 15g weight and vibration gone.
Users browsing this forum: Google Adsense [Bot] and 113 guests
