Dodgy Rear End issue.....
esp_mm-270
Re: Dodgy Rear End issue.....
Post by esp_mm-270 » Tue Aug 20, 2013 5:50 pm
hlbeckley wrote:Saw the title and thought maybe you had gone with firestarter to collect his RS yesterday
Lol, well there is a place for both of us in the rear :kissmyrings:
RIV
Post by RIV » Tue Aug 20, 2013 5:56 pm
I've just been out to my car I've been rocking the car the tyre's don't flex like yours, infact my car doesn't really move, that's prob down to the kw's maybe, I'm on my second set of good years it must be your tyres
esp_mm-270
Post by esp_mm-270 » Tue Aug 20, 2013 6:02 pm
Silas wrote:I've just been out to my car I've been rocking the car the tyre's don't flex like yours, infact my car doesn't really move, that's prob down to the kw's maybe, I'm on my second set of good years it must be your tyres
Thanks Silas, thats good for me to have a point of comparison and further conformation that they shouldn't do what they are :)
RIV
Post by RIV » Tue Aug 20, 2013 6:04 pm
Forgot to mention I have 275.30.19
esp_mm-270
Post by esp_mm-270 » Tue Aug 20, 2013 6:08 pm
Silas wrote:Forgot to mention I have 275.30.19
I have standard size.
RIV
Post by RIV » Tue Aug 20, 2013 6:20 pm
Can you swap them out with someone else's wheels to see what difference it makes ?
esp_mm-270
Post by esp_mm-270 » Tue Aug 20, 2013 6:29 pm
That would take the new tyres out of the issue. Hmmmm, I have someone in mind.......
brn7y
Post by brn7y » Tue Aug 20, 2013 6:31 pm
I did this also and mine does not move at all.
esp_mm-270
Post by esp_mm-270 » Tue Aug 20, 2013 6:33 pm
brn7y wrote:I did this also and mine does not move at all.
Thanks so much for checking :) Do you have 255/35/19's? Which make? Thanks in advance.
coffey555
Post by coffey555 » Tue Aug 20, 2013 6:35 pm
How many miles have you done since they were fitted?
Have you tried doing the same wobble test on the front of the car?
If it were my car I would take it for a steady drive on the motorway for at least half an hour to scrub the rears in and then gingerly see how it goes around corners then.
Easier and cheaper than buy two more tyres that you might not need.
Misano Red RS4 B7 Avant
esp_mm-270
Post by esp_mm-270 » Tue Aug 20, 2013 6:38 pm
coffey555 wrote:How many miles have you done since they were fitted?
They've done about 500 miles motor way and about 80-90 miles around town/country lanes.
Yep, did the front, rock solid.
Thanks for suggestions tho, keep them coming :)
coffey555
Post by coffey555 » Tue Aug 20, 2013 6:46 pm
Well they are certainly bedded in now then so not that!
Dal
Post by Dal » Tue Aug 20, 2013 6:47 pm
Just ran out and checked mine, no movement at all, OEM tyre size...
B8 RS4 in the fastest colour :smile_smoking:
esp_mm-270
Post by esp_mm-270 » Tue Aug 20, 2013 7:01 pm
Dal wrote:Just ran out and checked mine, no movement at all, OEM tyre size...
Ty so much. Its looking like tyres with all the peeps here with no movement.
moondog
Post by moondog » Tue Aug 20, 2013 7:02 pm
Bad batch of tyres? Hope not, as ive just put 4 of the same on mine. I'll be interested to see if it is the Goodys.
:shock:
Daytona B7 RS4 Avant soon to be terrorizing NZ roads.
Users browsing this forum: Bing [Bot] and 182 guests
