Sat Nav Plus - DIY install
It surprised me to find that the main navigation selection switches are on the right-hand side of the unit which make it slightly easier to use in a RHD car (IMO at least).
Diesel, the TFT on these units is excellent with a wide viewing angle.
2001 Silver S4 Avant
Hi
I am about to embark on moving from a basic sat nav (which has never really worked for some reason) to a sat nav plus, or, as I want TCM, more likely an RNS-E. Do you know anywhere I can get hold of a copy of the info from the TVWIZ site? I see he's been leant on.
Dave - any wish to do another install on an B5 S4? Thoughts on costs?
Nige - did you get there? I have a pre-face lift 1999 T S4. Did it work ok in the end?
Cheers.
Cheers.
If you have the facelift model then Navi+ "D" should work. You need a TMC/CAN gateway too.
Check your cluster for 3 connectors, GREEN, BLUE and GREY. If it has these 3 then it is can bus.
The TMC gateway/can Bridge is the cigarette packet sized module that converts the Bosch Can of the RNS-D to the Infotainment CAN of the cluster. It also receives the TMC channel messages from Classic FM and sends the, to the RNS-D.
Adirs4avant
What u have here it has been really helpfull however i have 2 wires left to connect from your write up it appears it would seem they need to be connected to back of dash if you could help be more than happy to let you drive one of the Fastest rs4 in the country this is nota joke 606bhp at the wheels 0-100 IN 6.6 second plz help verry much appreciated
Adirs4avant
