Whistling Power Steering
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
gavsteryoung
Post by gavsteryoung » Wed Nov 17, 2004 6:20 pm
Eversince I have bought my car, when I am parking and get to near full lock I get a whistling sound from my powersteering....
Anyone have any idea what this is? Or has anyone experienced this?
I have done about 8k like this and does not seem to lose fluid.
As im out of warrenty im lothed to take it to the steelers and for them to say I need a new Rack :lol: or pump...... as it works fine, just slightly annoying when parking.
Sorry for all the posts, I have a potential third problem but wont post until I confirm it! :shock:
cheers guys
SimonS4MTM
Post by SimonS4MTM » Wed Nov 17, 2004 6:35 pm
Yes, my current S4 and my old one both did this. When it is next in for a service i will get them to check the belt tension as i think this may be the cause. Unless it is a common "feature"
S4 OXON
Post by S4 OXON » Wed Nov 17, 2004 7:25 pm
yes it allso happens on mine, at near full lock , is this just how the cars are ? as mine has been into audi for 30k oil and bits :audibash: and nothing said and im sure if thay can get more money thay will so think it ok but now i use the nosie and a near full lock sound :jump:
Olly_K
Post by Olly_K » Wed Nov 17, 2004 7:41 pm
yep, mines the same
DavidT
Post by DavidT » Wed Nov 17, 2004 9:30 pm
And me, my 98 A4 was the same before that too.
BlackShadow
Post by BlackShadow » Wed Nov 17, 2004 10:49 pm
Mine's the same. I think most cars with power steering do this when they are on full lock. It's just that some cars are noiser than others.
Silver S4 Saloon
MTM Stage 4 (385 bhp), Mov'it Front Brakes, RS4 Rear Brakes, H&R Coilovers, Tanoga Shortshifter.
gavsteryoung
Post by gavsteryoung » Thu Nov 18, 2004 10:28 am
Glad you all have heard or had the same problems. Means I can tick it off my worry list! :ban:
Did anyone manage to rectify the problem at all?
SimonS4MTM
Post by SimonS4MTM » Thu Nov 18, 2004 11:45 am
If it is a common problem then it is probably that the power steering fluid is at high pressure when on full lock causing the noise.
Dippy
Post by Dippy » Thu Nov 18, 2004 1:42 pm
My power steering was making noise a few weeks ago. So I checked the oil and found it was less the the minimum - doh! :bash:
So I topped it up and it was fine. However it had prompted me to check the manual, which warned me not to have the car on full lock whilst stationary for more than * seconds (can't remember what * is).
So as Simon states, at full lock the oil is at max pressure and this could cause the noise. Having said that, my steering doesn't make any noise at any position (any more).
2001 Silver S4 Avant
Mik
Post by Mik » Fri Nov 19, 2004 4:39 pm
Mines the same, common problem with the pump. Eventually it will go really bad before it breaks. Had mine replaced - About £110 for the part + fitting
Mik
2014 Suzuka RS6
bjacks
Post by bjacks » Fri Nov 19, 2004 4:44 pm
Same on the RS. I've had a new rack and pump recently and it still makes the same noise - in fact, it's getting slightly worse than it was before.
Golich
Post by Golich » Fri Nov 19, 2004 8:48 pm
While I'm no expert on this. All power steering racks will make a different noise on full lock. As the high pressure oil is no longer moving the rack. Most units/systems have a pressure relief valve/bypass for the full lock case and this is what you are hearing. You may have noticed if you go to full lock most cars have a distinct additional restistance followed by the increase in noise for say the very last 5degrees of steering wheel rotation. Without looking this up I would imagine the oil is allowed to bypass upon the rack reaching a certain position and this is what causes the noise. I'm sure there will be info on the net about the design of power steering units.
Diesel
Post by Diesel » Fri Nov 19, 2004 11:52 pm
As mentioned its the bypass. I always wind the lock off a touch as it has always sounded a little mechanically un-sympathetic to hold it on full lock, causing this noise. D
Mik
Post by Mik » Sat Nov 20, 2004 1:51 pm
Also, I believe it actually says in the S4 manual that one should avoid keeping the wheel at full lock (for some reason).
My new pump also makes a very slight noise on full lock, but you will know about it if its failing - the noise becomes unbearable.
Mik
2014 Suzuka RS6
gavsteryoung
Post by gavsteryoung » Mon Nov 22, 2004 4:11 pm
Ok had a good check this morning of the fluid and it indeed is low!
Is there a specific power steering fluid I need and will my local Halfords sell it... for ease!
cheers
Users browsing this forum: Majestic-12 [Bot] and 38 guests
