Anyone used 123spareparts.co.uk?
MalcolmSu
Re: Anyone used 123spareparts.co.uk?
Post by MalcolmSu » Thu Aug 01, 2013 10:17 pm
well delivery w/b 12 August turned out to be yesterday :) Now praying for a dry day this weekend...
Post by Shoppinit » Fri Aug 02, 2013 8:11 am
Yay. Good news. :) They are peasy easy to change. Did you get also the kit with the retaining pins, etc? Personally I've never needed them, but seems like some people struggle to push them out.
MalcolmSu
Post by MalcolmSu » Fri Aug 02, 2013 10:28 am
I've done pads and refurb'd calipers before so wasn't anticipating this to be too much more difficult
Post by Shoppinit » Fri Aug 02, 2013 10:54 am
No, it's one of the easiest brake jobs on any car I have ever done. But the pins can corrode and seize apparently.
Keaney
Post by Keaney » Sat Nov 02, 2013 1:17 am
Looking at a set if new discs and pads and after a chat with Doug at MRC he said its possible to get them a bit cheaper instead of tps these days so figured I'd check here.
Shop to the rescue again haha!
So from what I gather people are ordering these, how do they compare to the tps ones?
Brake pads wise sounds like the brembo pads are still the best to have for a car that doesn't go on a track?
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Post by Shoppinit » Sat Nov 02, 2013 9:12 am
I'd go for OE pads.
Keaney
Post by Keaney » Sat Nov 02, 2013 9:59 am
I thought brembo pads were oe? Guessing tps for them is probably best?
Has beens:
Post by Shoppinit » Sat Nov 02, 2013 10:12 am
Brembo are OE for the C6 brakes. Pagid for the C5. Special compound, though (or at least, unknown compound) so definitely don't get the cheapo ECP Pagid pads.
Keaney
Post by Keaney » Sat Nov 02, 2013 12:56 pm
Thanks Shop, last 2 questions where would you get the pagid ones from if not from tps?
Do the zimmer discs have a aluminium centre like the oem ones?
Has beens:
Post by Shoppinit » Sat Nov 02, 2013 1:13 pm
I would try TPS or Virdee (on here). They are a bit pricey (as pads are) but i think they are the cheapest option for sufficient braking. Might be worth checking to see if there are any special deals on Ferodo DS2500 or Pagid RS4-2-x or R19 (or R29 - can never remember which is the road pad) but every time I have looked, OE has been cheapest. Be wary that some pad manufacturers sell them per wheel, rather than per axle. Ferodo do this for the pads for the 8 pot calipers. :bash:
Keaney
Post by Keaney » Sat Nov 02, 2013 1:31 pm
Looks like I'll be going for oem pads after having a look about at the other options.
Interested on how the zimmer discs compare though and if they are the same weight etc
Has beens:
Post by Shoppinit » Sat Nov 02, 2013 1:35 pm
The rear ones I bought are identical to the OE disks. Haven't tried the front ones. The OE 390mm disks are nice and cheap. :)
Gripper1
Post by Gripper1 » Sat Nov 02, 2013 11:47 pm
Front ones are exactly the same as the Audi ones. Just no Audi ID on the disc and associated premium :thumbs:
Keaney
Post by Keaney » Sun Nov 03, 2013 11:48 am
Great thanks for the help folks.
Has beens:
Keaney
Post by Keaney » Mon Nov 04, 2013 1:57 pm
just noticed 123spareparts are also on quidco too with 8% cashback when you spend over £120!
Has beens:
Users browsing this forum: No registered users and 175 guests
