Clunking noise ...
Re: Clunking noise ...
Post by bam_bam » Sun Jul 07, 2013 8:57 pm
Yes, it was the word dȉldo.
Post by Shoppinit » Sun Jul 07, 2013 9:11 pm
He is Dutch after all. Maybe it's to ease the transition from getting shafted by Audi.
mavada
Post by mavada » Mon Jul 08, 2013 9:05 am
Came across this...
Im not sure if the RS6 flange has the same diameter as the S8 one...
quattroworld.com Forums_ Driver's side output flange excessive play..pdf
(546.77 KiB) Downloaded 59 times
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
mavada
Post by mavada » Mon Jul 08, 2013 11:07 am
ive seen the flange axle part nr in ETKA has a B behind it, does that mean it has been upgraded? (01L 409 355 B @ 280 euro..)
Yellow Koni's
Post by Shoppinit » Mon Jul 08, 2013 11:15 am
Not necessarily.
mavada
Post by mavada » Tue Jul 09, 2013 10:25 pm
Assuming the S8 flange axle has the same diameter, dont think mine is worn...
Yellow Koni's
Post by Shoppinit » Wed Jul 10, 2013 9:13 am
Doesn't look like it. I would just put it back with the new oil seal, clean up the area around the diff, then see how it goes. If there's no more leaking and no play when the axle is in, then your problem is probably coming from somewhere else.
mavada
Post by mavada » Wed Jul 10, 2013 9:23 am
yeah i hope the leaking is gone with the new seal in, but the seal wont solve the play (and probably the play will get it leaking again after some time). the part that touches the flange is very flexible. You can see theres a metal spring behind the part that touches the flange. it can be modded to tighten the spring, but i dont touch it. So i think (if it cant be solved without having to take the engine/box out) i have to live with the clunk or get myself a black plus :sekret:
Yellow Koni's
mavada
Post by mavada » Wed Jul 10, 2013 3:55 pm
oil to use according to ETKA: G 052 145 A1
Found out that is API GL-5 spec.
Ive bought Kroon oil Syngear 75W90, found out its semi-synthetic...dont know if its that important to get full synthetic?
Kroon oil spec:
API GL-4/5
MIL-L-2105
Meets the requirements of VW 501.50
Yellow Koni's
Post by Shoppinit » Wed Jul 10, 2013 5:33 pm
Why'd you get non-synthetic stuff? I wouldn't use that, personally.
mavada
Post by mavada » Wed Jul 10, 2013 5:36 pm
i didnt show what type of synthetic it is, thought it was full. Stupid when i think about it :bash:
Yellow Koni's
Post by Shoppinit » Wed Jul 10, 2013 5:45 pm
Annoying. Still, it can't have cost too much. Use it to cook chips in for your kids and get some real stuff.
mavada
Post by mavada » Wed Jul 10, 2013 6:03 pm
yeah will do, its gonna be Motul Gear 300 75W90...
Yellow Koni's
mavada
Post by mavada » Fri Jul 12, 2013 10:14 am
...so the new seal is in, waiting for the oil to be delivered today...
Yellow Koni's
Post by Shoppinit » Fri Jul 12, 2013 10:16 am
^^That is one weird Dutch sextoy.
How'd you push it in, in the end?
Users browsing this forum: Bing [Bot], Google [Bot] and 114 guests
