What's the current DV of choice?
I have a couple of requirements -
Must be available in black
Must be simple and maintence free to an extent.
The nice guys at Forge have offered a good deal on some of their 007p's, just wondering what else was out there with my stipulations above. I really cannot be bothered pissing around with springs and the rest - just want a good pair of valves that work out the box.
Cheers lads,
Ben
Cheers lads,
Ben
Stop being such a girl Ben
Current : 2016 Audi SQ7
| Radical SR3 Supersport
| Ultima Evolution
Just get the Forge 007p's and a full set of springs. Use a bit of oil when fitting then, and they should slip in pretty quick. You may also want to get a couple of ickle juiblees (sp) for the vacum hose. You can change the springs on the forge DVs without taking them out.
Remember to check your DVs at every service and make sure the piston travel is not restricted. A good way to test this is to try to move the piston inside, easier without the spring, but make sure the cap is on as the piston travels inside the cap. They can be cleaned and regreased very easily.
| Ultima Evolution
Ta Phil - doesn't sound too taxing. Thinking about it, I now have a nice garage to work in (more excited about this than the housePhilT wrote:Just get the Forge 007p's and a full set of springs. Use a bit of oil when fitting then, and they should slip in pretty quick. You may also want to get a couple of ickle juiblees (sp) for the vacum hose. You can change the springs on the forge DVs without taking them out.
Cheers all
Ben
Not sure if the current ones are any better than the originals, but there were a couple of instances of the diaphram disappearing. Recommend people stick to the pistons.Or get the Forge diaphram race DV's - no springs !!
Has anyone tried these??
| Ultima Evolution
Forge supply a couple of PDFs here to assist in fitting and servicing. See bottom of the page here - http://www.forgemotorsport.co.uk/produc ... t=FMCL007P
I have a question... There has been a lot of talk over the years regarding the orientation of the DV being 'incorrect'. I assume it is because the pressure that is released hits the side of the DV piston and not the end. So, looking at the FMCL007PA ( http://www.forgemotorsport.co.uk/produc ... =FMCL007PA ), it would appear that this new DV is designed in a way that would allow it to be fitted the 'correct' way. What do you think?
| Ultima Evolution
I had hyperboost DVs on my chipped S4 and thought they did exactly what they were NOT supposed to do. i.e. the boost lag between shifts was very noticable. It was like change gear wait 1/2 second Aaa.. full boost there you are.
I'm not slagging Hyperboost valves more the whole piston type design over a diaphram type. I suppose I should ask was my experience unique or have others noticed this with their piston type DVs? Of course the boost lag could also be exaggerated with the increase in boost owing to the remap?
£112 each for the new forge diaphram is one hell of lot of dosh as is the £70 or whatever it is now for the piston types if they don't make any difference!!
Users browsing this forum: Google Adsense [Bot] and 68 guests
