Best thing is to look at the thread length remaining on the front (not the rear). Lift the car and remove the wheel and you should easily be able to scrape the crud away to see.
I did measure it once. I'll have a look.
pics of cars with pss9s
Re: pics of cars with pss9s
Measurements from the floor to the start of the wheel arch in the axis of the center of the wheel:
Front: 672 mm
Rear: 675 mm
Front: 672 mm
Rear: 675 mm
Hey
so between 620 and 625 on the front for me so probably a bit of room to go up then
t.
t.
- philipinoz
Hmmm, mine is on PSS9s too, and I've got the fronts as high as I can get - I think!Shoppinit wrote:Measurements from the floor to the start of the wheel arch in the axis of the center of the wheel:
Front: 672 mm
Rear: 675 mm
Front:650mm
Rear: 653mm
Seems to sit okay - was better than it was after the PSS9s were fitted when rear was at 685mm! Ah well, next weekend's job, see if I can get 20mm more height out of the fronts.
philip
2014 RS6 (Daytona Grey)
Previous Drives: Astra -> Cavalier SRi -> Audi 90q -> A4 2.8q -> A4 2.4q -> Mercedes ML430 (Carlsson) -> RS6 C5
Maybe gravity is stronger in Oz to stop you flying off into space.
My car is sitting lower than standard but not excessively low.
I'm tempted to wind it up a little to see if the ride is better.
MG
MG
Users browsing this forum: Steve2003rs6 and 118 guests
