Anyone tried H&R springs on theirs?
dan101smith
- 1st Gear
I need to replace my front springs. I can either go with OEM from the dealer, or H&R to replace all of them. I've got new OEM shocks.
Has anyone tried the H&R springs? Do they actually drop it much? I'm not hugely bothered about lowering it, as a decent ride is more important! The only reason I'm considering them is that a set of 4 H&R costs only slightly more than two OEM...
Re: Anyone tried H&R springs on theirs?
I have H&R's with stock shocks. Lowered 30mm all round, looks good and ride is good, far less barge-like, feels much tighter, bit harder but not bone crunching as the stock shocks keep it civil!
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
As ASC, i have the -30mm H&Rs with stock shocks and all is good.. altho i do ground my milltek quite a bit, as it hangs lower than a std exhaust :-O
goose
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Past:
Same here, got them with 10mm spacers all round and I love the stance. Handling is just a touch stiffer than stock but hardly noticeable. Let's face it the roads in this country are crap, if your hitting potholes it doesn't matter what your running, so you might as well look good doing it!
dan101smith
- 1st Gear
Cheers guys.
I think I'm going to stick to OEM, though. Should still be significantly better than the worn springs that are on there now!
Good choice, I've got the H&Rs on mine and I really don't like them at all!
Far too firm for the rubbish roads where I live..
quick heads-up.. continued use of -30mm H&R springs with std shocks and 10mm H&R rear spacers, and I've just had to replace the OSR wheel arch liner as the tyre had knocked out a retaining clip and the liner dropped onto the tyre and wore a huge hole in it!!
60 odd quid part, plus a bit of labour and the VAT and thankyou very much £140
goose
goose
Current:
Past:
Past:
Are you bottoming out? I've got the exact same set up and never bottom out at the back (never really have anything heavy in the boot though). The front sometimes rubs if pushing on into a dip but otherwise have had no problems.
i have a feeling i must have either hit a pot-hole really hard and the tyre banged the clip out.. or it was when i had a couple of my biffa mates in the car who play Defense for the Reading Renegades lol!Jocky wrote:Are you bottoming out? I've got the exact same set up and never bottom out at the back (never really have anything heavy in the boot though). The front sometimes rubs if pushing on into a dip but otherwise have had no problems.
goose
Current:
Past:
Past:
randomshenans
- 1st Gear
Anyone got a pic of stock vs 30mm drop? I have been offered a set
Users browsing this forum: No registered users and 11 guests
