Clunking noise ...
mavada
Re: Clunking noise ...
Post by mavada » Mon Jun 10, 2013 10:59 am
these are the parts were talking about, not from rs6, but similar stuff...
looking at it i dont think its the flangeshaft itself, has to be a bearing or shim...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Post by Shoppinit » Mon Jun 10, 2013 11:11 am
Can you pull it out to inspect? You've already got the drive shaft off haven't you?
mavada
Post by mavada » Mon Jun 10, 2013 12:14 pm
Shoppinit wrote:Can you pull it out to inspect? You've already got the drive shaft off haven't you?
well, we did it outside in front of the garage, cos theres more space. put it together cos of time limit. but will have another go inside the garage...
We couldnt check oillevel cos the front was on jackstands...
Wander if theres any oil in with this amount of play, think the outer seal isnt working cos of the play...
If its a bearing, its an engine/gearbox out job, as elsawin mentions.. we couldnt see a way to get the part of in which the flangeaxle is in. theres a piece of the exhaust running in front of it, also a piece of the frame/subframe (dont know how its called)
Ive never heard someone with the same trouble and without taking the engine out...
So, not really sure what to do next... :cry:Just keep driving with this clunking and possible causing more damage, or....
Yellow Koni's
mavada
Post by mavada » Mon Jun 10, 2013 1:10 pm
Yellow Koni's
mavada
Post by mavada » Mon Jun 10, 2013 4:57 pm
...but Elsawin says to remove the engine for O2's as well :o
From Elsawin:
- Remove front exhaust pipe (left-side) and front exhaust pipe (right-side) with flexible element → Engine, mechanics; Rep. Gr.26. – Remove gearbox support (right-side)
Removing and installing front exhaust pipe (right-side) – Remove engine → Chapter.
Yellow Koni's
mavada
Post by mavada » Mon Jun 17, 2013 2:54 pm
...Anyone got a clear pic taken from the right side where i can clearly see the diff case and turbo etc.?
Yellow Koni's
mavada
Post by mavada » Mon Jun 17, 2013 3:31 pm
...found one, but not clear if its (diff case...) removeable in situ...
Yellow Koni's
mavada
Post by mavada » Mon Jun 17, 2013 6:47 pm
ah, ive seen its possible... :shock:
Yellow Koni's
Post by Shoppinit » Mon Jun 17, 2013 7:31 pm
Possible, but not easy. It's a pain to have to remove the turbo. Better pray the bolts aren't seized...
Post by chunky79 » Mon Jun 17, 2013 7:33 pm
Looks a right byatch of a job.
mavada
Post by mavada » Mon Jun 17, 2013 8:23 pm
..its a challenge...like this:
Yellow Koni's
mavada
Post by mavada » Mon Jun 17, 2013 8:34 pm
Shoppinit wrote:Possible, but not easy. It's a pain to have to remove the turbo. Better pray the bolts aren't seized...
i think by just loosen the turbo will have prob enough space to get the diffcase out...
Yellow Koni's
mavada
Post by mavada » Sat Jun 29, 2013 8:43 pm
...i managed to get the flange axle out and noticed the needlebearing can move in-and out for about 1-2 mm. Dont know if thats normal.
The part that covers the needlebearings hasnt got play. So i think the diff itself neither.
Was surprised there was oil coming out after all those kms leaking.
But i dont understand why i can move the flange in- and oud for about 1,5-2mm, but when i just insert the bold without the flange theres no play at all.
Yellow Koni's
Post by Shoppinit » Sat Jun 29, 2013 8:53 pm
Excellent job, Mav! What did you have to do to get enough room to remove the flange? (Told ya it could be done.. .;) )
Not sure what your question is?
mavada
Post by mavada » Sat Jun 29, 2013 8:55 pm
well, theres still play in it, trouble is to get the diffcase out to replace the bearing...
Yellow Koni's
Users browsing this forum: No registered users and 704 guests
