RS4 Engine Failures - Know of any?
sakimano
Post by sakimano » Mon Jun 03, 2013 2:03 pm
We have seen a few engine failures crop up on both sides of the atlantic lately. Just wanted to get a handle on what is the weak spot in the motor that is causing these failures. As the car gets older we can expect to see this a bit more.
There is no epidemic...let's be clear up front about that. I have personally heard of maybe 10 RS4s getting replacement engines due to failure, either by something mechanically catastrophic, scored cylinder walls thanks to our friend Carbon, or other undiagnosed issues. Out of something like 10,000 Rs4s out there, that's not too bad, but that's all I've heard. There are clearly far more out there but as I said, even then it will be a pretty small number on a percentage basis, especially considering we're 6-7 years past when the RS4 first went on sale.
There was one on here recently that turned into a 15 page thread. Fellow was just cruising along and the motor went kaboom. Anyone remember his username? He was hoping to sell the car, and may have done so already after warranty replacement (I believe it was warranty replaced).
Then there was an RS4 I believe in southern Europe that had a badly scored cylinder wall, I think it was diagnosed as a result of a carbon chunk making it's way into the cylinder and being ground between the piston and the wall. There was another similar story like that in Australia.
Another engine a few years ago failed violently and the oil pan was full of metal debris. There was a great picture of it. Kind of astonishing.
Any others that we know about? If there are any, please post up your recollection. Ideally we should gather the following, but if you only remember a few scraps (like my failing recollections above) post what you remember and maybe other people can fill in the blanks
1. link to the discussion
2. brief description of the failure
3. diagnosis/cause if determined
4. relevant modifications to the car (tuning, forced induction etc however an exhaust isn't going to cause an engine failure)
5. mileage
6. other problems with the car before failure/replcaement of the engine
toyneg
Re: RS4 Engine Failures - Know of any?
Post by toyneg » Mon Jun 03, 2013 2:13 pm
was this thread I think you were referring to?
http://forum.rs246.com/viewtopic.php?f= ... lit=engine
Post by MikeFish » Mon Jun 03, 2013 2:17 pm
I'm on the phone so bit tricky searching for the right threads but the recent one you talk about was rs4martin or something similar. Replaced under warranty then sold on and the new owner came on here was reading yesterday about another one in Europe somewhere in the terraclean thread, right bear the end he said he had a carbon clean at 80000km, but had a new engine at 64000km I think.
Post by MikeFish » Mon Jun 03, 2013 2:18 pm
Dammit, I typed all that in the phone and was beaten to the punch with a link!
sakimano
Post by sakimano » Mon Jun 03, 2013 2:22 pm
Yes, that's the recent one thanks guys.
What was the terraclean thread one? I'll have to have a look...
Post by MikeFish » Mon Jun 03, 2013 5:29 pm
sakimano wrote:Yes, that's the recent one thanks guys.
From the Terraclean thread:
MortenJuul wrote:The problem with that, is that all the carbon is back after 2k miles :(
I had a boroscope inspection of my intake - this was when that car was 3 years old - i had done 80.000 km - but the engine swapped due to crack in the block at 64.000 (full AUDI warrenty - 9 pages invoice, complete engine swap
So this is after 16.000 km (car done 80.000 km)
This was done March 2012 - We did a complete carbon clean - off with the intake manifold and use bell add clening fuids and foam (+ manual work)
http://www.belladd.dk/en/SpecialRens/Cl ... skine.html
The I installed the water methanol system at the same time
This is what it looks like October 12th - 7 months and 108.000 km - = 28.000 km since the clean - remember the initial "mess" was from 16.000 km!!
I also looked at catch can or ventilate to air from the PCV, but catch can would mean freezing water in the can in the winter and open blow off, smells really bad (oil)
Methanol is my solution - BTW - when doing trackdays I lower my oil temps by 20C by turning on the meth, since the water in the mix also cools cylinder temps hence oiltemps
This is the actual post:
http://forum.rs246.com/viewtopic.php?f= ... 50#p603082
RS04YOB
Post by RS04YOB » Mon Jun 03, 2013 8:31 pm
The Terraclean process will be listed soon no doubt
ArthurPE
Post by ArthurPE » Mon Jun 03, 2013 9:25 pm
someone had posted production numbers here and it was over 15,000 iirc, saloon, avant and cabs
I've only heard of a hndful of failures, most scoring of the cylinder, only 1 catastrophic, a broken rod
sakimano
Post by sakimano » Mon Jun 03, 2013 9:45 pm
ArthurPE wrote:someone had posted production numbers here and it was over 15,000 iirc, saloon, avant and cabs
Do you remember the one with the picture of the oil pan a few years ago? I will try to dig it up.
ha, that wasn't bad. Found it.
6500 miles. Driver claimed it just went kaboom. Bone stock engine.
Looks pretty violent!
One of the techs suspected a money shift, however Audi picked up the tab being unable to prove anything
Gumball0r
Post by Gumball0r » Mon Jun 03, 2013 11:06 pm
I had an engine failure 1,5 years ago.
http://forum.rs246.com/viewtopic.php?f=35&t=92485
Rod in cylinder 6 gave up.
No explanation as to why it happened, guess it was some kind of manufacturing defect but at 90.000 miles ? . Audi installed a new engine as a gesture of goodwill.
No modifications/tuning.
Old engine drank oil, 1 liter/1000 miles. Now 1l/6-7.000 miles. I followed Audi's engine run in instructions on the new engine, and I'm thinking that may be the difference. I did'nt own the car from new, so I have no idea how the old engine was driven for the first 20.000 miles.
spikeyboy101
Post by spikeyboy101 » Tue Jun 04, 2013 1:30 pm
Rs4martins was a con rod failure as well i think - and looking at the picture above i would summise that was con rod failure.
sonny
Post by sonny » Wed Jun 05, 2013 1:53 am
Its funny, how we can actually remember and name most of the engine failures of these cars.
If you guys ever go onto Clio Sport this thing happens on a weekly basis lol
Got to love Audi.
p.s Coreplugs falling out of IM is another engine killer.
adsgreen
Post by adsgreen » Wed Jun 05, 2013 8:04 am
Doesn't look like my experience if an over rev - normally it'd kill all the valves zend maybe pistons. Bending x con rid like that takes a lot.
It's very similar to the recent failure in that con rod appears to have been bent during compression...
Users browsing this forum: Google Adsense [Bot] and 91 guests
