Lights to LHD?
5.0 V10 50v biturbo - 571 bhp
PorkaFly
Lights to LHD?
Post by PorkaFly » Sun Jun 02, 2013 2:14 am
Question for you chaps, without digging the manual out.
Can the C6 RS6 lights be switched to LHD and if so is it easy to do DIY or is it a major PITA?
Txs
PF
2009 RS6 Avant (C6) - Monza
2011 GT3RS - Grey/Gold
2012 Range Rover 4.4 TdV8 Westminster - Black
PorkaFly
Re: Lights to LHD?
Post by PorkaFly » Sun Jun 02, 2013 10:23 pm
Wow...29 Views and no response...
Someone?
Ta
PF
C6NVS
Re: Lights to LHD?
Post by C6NVS » Mon Jun 03, 2013 6:23 am
Hi Porka,
Do you have a Vagcom?
Shamelessly copied from the interweb:
Adaptation
Channel 010: Tourist Solution
When driving in countries where driving is performed on the opposite side as in the native country the headlights must be changed over to avoid blinding the oncoming traffic. When active/enabled the Fault Code 02988 will be stored.
0 = Disabled
1 = Enabled
Note: Only supported for 8P0-907-357-C @ 0020 or newer! Earlier versions require a mechanical Adjustment as described in the Factory Repair Manual.
To change over Bi-Xenon headlights for European driving using VAG-COM. 24-Mar-08
Select Control Module - Select 55 Xenon Range - Select Adaptation - 10
Channel Number - Use the up arrow to move up to Channel 10
New Value - use the up and down arrow to change the ?0? to ?1? - Click Save to store the new value
A yellow Headlight Range Error should be displayed on the DIS together with a beep.
This will beep and show each time the ignition is turned on as a warning that the headlights are set
for European Driving.
Channel 09 may need to be changed from ?0? to ?1? for the warning to show and changed back
afterwards.
Daytona C6 RS6 Avant: Demand Engineering Exhaust (Downpipes custom to tip)
Soon to add: Hybrid Turbos; Uprated Gearbox; Marston Intercoolers; ECU / TCU mapping
barryrs
Re: Lights to LHD?
Post by barryrs » Mon Jun 03, 2013 9:16 am
My manual states that the dip settings have to be changed by a qualified workshop.
How stupid; so i have to drive to an Audi dealer to have my dip settings adjusted and therefore dazzle UK motorists until im across the channel. I know Alfa come in for a lot of stick but at least they incorporated a switch into the zenon headlights so that you can switch manually in a couple of seconds.
535dboy
Re: Lights to LHD?
Post by 535dboy » Mon Jun 03, 2013 9:39 am
I thought some you could do through MMI?
Have you looked
Otherwise dealer job
Are you driving at night?
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
Seat Ibiza excellence Lux!
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2017 AMG E class wagon
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
PorkaFly
Re: Lights to LHD?
Post by PorkaFly » Mon Jun 03, 2013 11:20 am
C6NVS wrote:Hi Porka,
Do you have a vagcom?
Adaptation
0 = Disabled
1 = Enabled
afterwards.
Thank you all for your responses. My manual/suede folder is packed away and haven't tried the MMI, so will do that today.
Don't have a VagCom, but as Barry says a real PItA if this is an Audi dealer thing. If it can't be done via MMI then VagCom it will have to be...how much is one do those?
I guess the underlying thinking behind my question was is it a light unit change if you want to drive it for extended periods in Europe or even register it in Europe more permanently?! I was hoping for such expensive dynamic units it would be a lever or software change so it remains the same light unit, as that would be a mega expensive job with new lights and bumper off (which is how they are done).
If anyone knows more from personal experience/knowledge pls educate the rest of us.
Ta
PF
535dboy
Re: Lights to LHD?
Post by 535dboy » Mon Jun 03, 2013 11:27 am
In mine it is in vehicle settings, exterior lightin and option there
I travel there a lot but car (lotus) is always parked up overnight so don't bother
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
barryrs
Re: Lights to LHD?
Post by barryrs » Mon Jun 03, 2013 11:40 am
Ive just checked my 2G MMI and under Exterior Lighting i only have the following options.
Coming home
leaving home
Daytime running lights
Nothing about changing the headlights for LHD and my manual refers me to Audi.
535dboy
Re: Lights to LHD?
Post by 535dboy » Mon Jun 03, 2013 11:47 am
barryrs wrote:Ive just checked my 2G MMI and under Exterior Lighting i only have the following options.
Coming home
leaving home
It's the forth option down so presumably not then
We had to dealer visit for my wife's old TT.
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
C6NVS
Re: Lights to LHD?
Post by C6NVS » Mon Jun 03, 2013 1:15 pm
PF, I'm not too far from you, in SW London. When I'm back in Blighty (9th June), I'm happy to bring my Vagcom to you and give it a try.
sixspeed
Re: Lights to LHD?
Post by sixspeed » Mon Jun 03, 2013 5:30 pm
Could I commission your services also? :D
2009 Sepang Blue C6 RS6 Saloon - H&S exhaust with de-cat and Vabric valves - Stage Two MRC next!
2007 Alpine White BMW Z4M Coupe - trackday toy with lots of mods!
C6NVS
Re: Lights to LHD?
Post by C6NVS » Tue Jun 04, 2013 6:20 am
Sure ss, PM me details
PorkaFly
Re: Lights to LHD?
Post by PorkaFly » Tue Jul 09, 2013 12:08 am
C6NVS wrote:PF, I'm not too far from you, in SW London. When I'm back in Blighty (9th June), I'm happy to bring my vagcom to you and give it a try.
C6NVS - many thanks for the offer. I think I'm going to buy a VagCom myself.
Which one out of these...assume one is just a later version, as well as being cheaper?
http://www.ebay.co.uk/itm/VCDS-Diagnost ... 20d4fbca88
Or
http://www.ebay.co.uk/itm/Vag-Com-Vcds- ... 3f26d15a83
And is price long about right?
Txs
PF
doodlebug
Re: Lights to LHD?
Post by doodlebug » Tue Jul 09, 2013 7:02 am
Can confirm it's done via Vagcom. Had it done for my recent trip to France. Local stealer charged me £25, FOC to put them back to RHD.
C6NVS
Re: Lights to LHD?
Post by C6NVS » Tue Jul 09, 2013 7:49 am
PF, I can't confirm the ebay cables. There are some on here that have tried certain ebay variants with different levels of success.
If you decide to go for a geniune registered version, I can reccomend Nigel at sales @ Vagcom.biz. Well known supplier of genuine cable on many vag forums.
Users browsing this forum: No registered users and 147 guests
