KWv3 Height Adjustment question
sync24
Post by sync24 » Tue May 14, 2013 10:01 pm
I've had my KWv3's installed by AMD last week and I am happy with the settings I chose. 7 Bump from Hard, 8 rebound from Soft [Apparently 'fast road' from Doug at MRC].
I ended up grinding down the front/rear liner mudflaps a little at the weekend to stop minor rubbing but this mod was very straight forward IMO.
I want to fine tune the ride height at the front as I am not 100% happy with it just yet but I can't find a PDF describing the process - even the guide booklet that came with the suspension does not mention how to adjust the height. I assume it's just a case of moving the purple collar with the supplied C spanner? I guess I can do this at home with the front wheels off and the car on stands if I take care to adjust both the same. I am not a mechanic by any means but have reasonable skills to tackle minor jobs :)
Can someone enlighten me the 'proper' way to adjust the ride height [I am happy with the bump/rebound settings]
When I'm done - I'll post some before and after pics.
Kev.
Rick_RS4
Re: KWv3 Height Adjustment question
Post by Rick_RS4 » Tue May 14, 2013 10:25 pm
raise or lower, measure from floor to top of wheel arch both sides, trial and error, there isnt a specific 3 turns and its 20mm lower
sync24
Post by sync24 » Tue May 14, 2013 10:31 pm
Cheers Rick - just measure and then use the cspanner to adjust height then?
RS4pete
Post by RS4pete » Tue May 14, 2013 11:30 pm
I measured/counted threads on coilover body to lower equally on either side.
B7 RS4
Mi16'd 205 1.9 Gti
1999 Yamaha R6
White Transit :)
slowmonkey
Post by slowmonkey » Wed May 15, 2013 4:07 pm
I think the trick with adjusting coilovers is to ensure that you have level ride height all round before you do any adjusting to where you want the ride height to be. I think from memory if you raise the ride height say 1cm on one side it'll drop the opposite side by half the measurement so you have to factor all that in. A vernier gauge to measure lock ring to a fixed point on the car is also a good idea, but of course you can count threads.
| 2007 Daytona Avant | Buckets | 20" BBS CK's | H&R Coilovers | Valved Milltek res | hole in the fuel tank|
sonny
Post by sonny » Thu May 16, 2013 2:43 pm
Use a metal ruler, measure the lower ring, say 5mm down, then lower the top collar (with spring) to the bottom collar. Then mark with a bit of paint (tipex) to check for slippage.
Easy really.
If car has been corner weighted then the measurements will be different on all for corners unless the correct ballast weight is in driver seat,
sync24
Post by sync24 » Thu May 16, 2013 4:58 pm
Thanks everyone at the moment it's very light rubbing on the passenger side and the driver's side is visibly higher - FFS - I can't be going back to AMD for a 3rd time - I am going to see if my local friendly tyre Shop will help me on Sat... :-(
Jph
Post by Jph » Thu May 16, 2013 5:15 pm
You can actually adjust the front KW's without even removing the wheels if you have long skinny arms - I've done it several times on my own car ;-)
Where in kent are you? I'm in E-Sussex but would be willing to lend a hand this coming saturday if you aren't too far away.
sync24
Post by sync24 » Thu May 16, 2013 5:27 pm
PM'd u jph
sync24
Post by sync24 » Fri May 17, 2013 10:00 pm
Rule 1.
For reference...
Current height
This one rubs [hides face on kerbed rim :oops: ]
Rear height
scaghead
Post by scaghead » Sat May 18, 2013 6:03 pm
Is it me fella or is your rear ride height higher than it was the other week when it was at amd? When I looked at your motor when it was there I thought it looked lower?.
sync24
Post by sync24 » Sat May 18, 2013 8:08 pm
scaghead wrote:Is it me fella or is your rear ride height higher than it was the other week when it was at amd? When I looked at your motor when it was there I thought it looked lower?.
It's not you fella :) When you saw it at AMD it had 275x30x19's on it with SS+ springs & DRC shocks and no spacers and the rear looked pretty low. I think now now I've gone back to 255's the car is a little higher and when I had the coilovers fitted I asked AMD to match the SS+ height - This ended up with some rubbing so they have been lifted up a little which is why it looks different. Now I know how to adjust the coilovers and I know the cause of the rubbing I can get this sorted and then adjust the ride height to get it lower than when you saw it.
sync24
Post by sync24 » Mon May 27, 2013 5:43 pm
Had my inner arch lips rolled yesterday - guy did a good job and I can see no paint cracking ETC - this has resulted in a nice fit for the front
I am back running 8mm spacers and I've dropped the front quiet a bit -a two day test ride has resulted in zero rubbing even with the car 4 up and some spirited national speed limit B road storming. I am happy with the height now - off to see Jonathan [JHM] in a few weeks to get rears sorted.
Got there in the end!
Users browsing this forum: Bing [Bot], Google [Bot] and 226 guests
