Re: Stage 1 Re-map
captrs6
Re: Re: Stage 1 Re-map
http://www.revotechnik.com/type/1056/222/
According to the Revo site, the car gets pushed up to 515bhp
Adjustability
Boost Throttle Fueling Timing
yes no no yes
Adjustability
yes no no yes
2003 C5 RS6 - Stage 1 Re-map, KW Coilover Kit.
The C5 is the S&M of car ownership - "Pleasure and pain".
Oh, Revo...
Should've got Viper to do it.
Does it actually feel faster than before? At 3,000 RPM it should feel fecking insane after a map.
captrs6
Amar - there is no insane feeling!
Re: Stage 1 Re-map
The Revo on mine was allegedly 520bhp and was done by the first owner around 2004/5 .
When it went on Dougs rolling road it came out as 484, which i was happy with.
It IS a plug and play one, as i got the original flash drive with the car.
i will post the graphs up on here later for you from Dougs/MRC.
However, once mine hits 30mph, it does take off , so maybe its not the complete answer to your original problem
captrs6
ahooga - how does it feeling when your 60+??
Mine was 495 on an MRC stg 1 but it's not always the headline figure that gives the performance, it's more about the torque and how it's delivered.
captrs6
Re: Stage 1 Re-map
Bam - hard to explain, but it doesnt seem to have the grunt. Scan will hopefully highlight the issues
Re: Stage 1 Re-map
Hi Guys , the car has a viper stage 1 map not a revo stage 1 .
The car was tested before and after and was makeing the correct boost .
Please call us if your still unsure .
grizz
grizz
Unit 20
0151 3366888
0151 3366888
Sheer acceleration, push back in the seat job. Had a little dabble the other day and was pulling like a train from 20ish upto 140 kleptons ( i eased off at that point) I was still being pushed back in the seat at 140. When people ask me how it goes, i say ' you know how a car pushes you back in the seat under acceleration, then they say 'yea' , and i say, well this monster tries to shove you down the gap between the backrest and base.............in the BACK seat'captrs6 wrote:ahooga - how does it feeling when your 60+??
It IS pure violent force/drive from 25ish upwards AND keeps the kids quiet on the school run cause their down by the battery somewhere.
Its only the initial take off that is slow, i say slow meaning compared with another 6 , once its rolling at 2500-3000 its what you'd expect.
Doug told me that the ECU isn't requesting boost till later than a normal/standard map which he found found surprising. we didn't remap it or anything at the time as the object was to see how the car went and what condition it was in. Car was advertised as 520 when i bought it and i was curious, that's the reason i took it to MRC..
My cars remap was done many years ago by the previous owner at Audi's suggestion, as they said it should improve the fuel efficiency. I spoke with the previous owner, and he said his was one of the earliest remaps that Revo did as it was done quite cheaply to aid revo in the development of it. Audi never agreed to remapping cars then( warranty), but this was all done by gentleman's agreement.
Do the vcds scan later to see if it shows anything though, as your problem my not be anything to do with the remap.
EDIT
grizz posted while i was typing
given what he said about the car showing correct boost , its probably something unrelated to the remap.
Did the car seem OK when you took it home from unit20 ? did it go like billy o ( dont tell us you didn't try it
- Mr Footlong
Brilliant, thanks for clearing that up Grizz. Capt, as mentioned from the beginning, get that VCDS log and anything else that Grizz has asked for and hopefully you guys will get your mind put at ease pretty sharpish!
Current:
Gone:
Gone:
captrs6
Thanks for the confirmation Grizz.
I will do the scan and post the results up for your thoughts.
Will also do a running test against my friends Beemer Z4 to use as a visual guage to see how far back he is!
Grizz - do you require anything else???
captrs6
Ahoooga - that was a great description!!
bam_bam wrote:Oh, Revo...
grizz wrote:Hi Guys , the car has a viper stage 1 map not a revo stage 1 .
grizz
captrs6
Re: Stage 1 Re-map
Hi All
First scan done - my friend has VCDS release version 11.11.5 - full version.
It has produced the following faults. Faults were cleared and nothing has came up on re-scan.
Car will now go for run...
thoughts please guys.. Slighlty worried about 4 engine faults.
Capt
Address 01: Engine Labels: None
Part No: Erprobung
Component: W13 257RNKA5.HEXG EU3
Coding: 0010752
Shop #: WSC 33278 133 00032
VCID: B461D9E5D48BACB8754
4 Faults Found:
18325 - Relay for Coolant After-Run (J151)
P1917 - 004 - Open Circuit
18058 - Powertrain Data Bus
P1650 - 004 - Missing Message from Instrument Cluster - Intermittent
17963 - Charge Pressure
P1555 - 001 - Maximum Limit Exceeded
16825 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 00000
VCID: 6CD181851C3BB478ED4
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 35-10 - Missing Message from ECU - Intermittent
Capt
Part No: Erprobung
Coding: 0010752
4 Faults Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Users browsing this forum: Google [Bot] and 142 guests
