Health check at mrc 309bhp vac issues and decoke
Jamiestanton
Post by Jamiestanton » Tue May 14, 2013 9:05 pm
Car is at mrc went in for decoke and stage 2 mapping with stage 1 manifold
1 st run on the dyno made 309 ps and 423nm has vac issues and in need of a decoke so when I get it back its should be a different car :biggrin3:
2006 black audi rs4 b7 mrc stage 2 stage 2 manifold de cats miltek coil overs light weight flywheel black optics 445bhp 470nm
Spaceman_RS4
Re: Health check at mrc 309bhp vac issues and decoke
Post by Spaceman_RS4 » Tue May 14, 2013 9:41 pm
Wow well done mate your going to be one happy chap when you get it back bud
Ordered b9 S4 Avant ibis white
Panther black 8V RS3
Misano Red B7 RS4 Saloon
jaysrs4
Post by jaysrs4 » Tue May 14, 2013 9:55 pm
Awesome! Would you mind telling me how much that's setting you back please?
Feel free to PM me if appropriate.
sync24
Post by sync24 » Tue May 14, 2013 10:03 pm
Wow - that's gonna feel great when you get it back - I am thinking about MRC work as well - so would be good to see the results. Don't forget to list the full car spec!
lengster1
Post by lengster1 » Tue May 14, 2013 10:38 pm
CAI is well worthwhile if you can stretch to it at same time,you should be north of 400 when you get it back keep us posted.
Jamiestanton
Post by Jamiestanton » Tue May 14, 2013 10:46 pm
He said hopefully arround 440 what is cai
RIV
Post by RIV » Tue May 14, 2013 10:54 pm
what is cai
Cock arse injection
hlbeckley
Post by hlbeckley » Wed May 15, 2013 7:05 am
Silas wrote:
what is cai
Cock arse injection
Hahahaha hahahaha
Cold air intake
ArthurPE
Post by ArthurPE » Wed May 15, 2013 2:46 pm
309 at the wheels or at the flywheel?
torque is ~312 lb ft which is essentially the rated (317)
if at the wheels, BIG vaccum issue
Mr V10
Post by Mr V10 » Wed May 15, 2013 2:49 pm
Flywheel, it's only you lot across the pond that do the 'at the wheels' rubbish.
MaLicE
Post by MaLicE » Wed May 15, 2013 3:01 pm
Amar wrote:Flywheel, it's only you lot across the pond that do the 'at the wheels' rubbish.
technically its at the fly figures that are "rubbish" as you put it! when a car is put on a rolling road, the rollers which the wheels are driving is what gives the power figure, hence a AT THE WHEEL figure is acutally what power you are putting down on the road.
the AT THE FLY figure which everyone seems to get a boner about is a "guestimate" the rolling road operator has a "transmission loss" figure, that they input in to the computer to give a "at the fly" figure... the only way to get a true "at the fly" reading is to remove the engine and put it on an engine dyno where it will measure the power from the flywheel!
so if anything your comment is "rubbish".
Mr V10
Post by Mr V10 » Wed May 15, 2013 3:19 pm
I know the difference between wheel/crank outputs, and how the dyno works out crank power. However, as manufactures don’t issue WHP figures, they mean feck all to me; wheel horsepower is a bit too geeky/techy for me. My comment wasn’t intended to be rude by the way, maybe I should have used a smiley or two.
RIV
Post by RIV » Wed May 15, 2013 3:19 pm
No come back from that answer, ouch!!!
ArthurPE
Post by ArthurPE » Wed May 15, 2013 3:30 pm
actually converting to flywheel is 'rubbish'
no way to know driveline losses without measuring them, too many variables: wheel slip, tire pressure, etc.
and the value is made even less credible unless the conversion factor is shared
the only way to know flywheel is to pull the engine and put it on a true engine dynomometer
anything else is a wag
ArthurPE
Post by ArthurPE » Wed May 15, 2013 3:31 pm
bingo :thumbs:
