Anyone have there decoke pre+post results?
Covkiller
Re: Anyone have there decoke pre+post results?
Post by Covkiller » Thu Apr 18, 2013 8:15 am
Gents
neil1003 - I paid £1498.26 and very satisfied, I've also had the Terraclean done for £96
Timester - I went to Revo for a change, this is my 2nd RS4 B7 and I am taking a different approach to mods. I used MRC for my 1st RS4 and they did a great job.
Gavla
Post by Gavla » Thu Apr 18, 2013 8:28 am
I went for REVO Stage 2 but to be honest was not impressed - mainly down to the lack of functionality - No linear throttle option in non sport mode (when you want to drive normally) and quiet mode start mode. (when revs stay at 1.8-2K for 30 secs right on exhaust resonance - just annoyed me every morning. Unless they have changed their maps in the past 9 months? worth checking..
RS4 (B7) Saloon Phantom Black, Black Optics, Tech Pack, KW Lowering Spring Kit, Stern Adjustable Arms, MRC Stage 2, Stage 1 Manifold, CAF, LOBA Stage 1 Clutch,
447ps/490nm (MRC), Scorpion Exhaust Non-Res Black Tips, Pre-cats gutted, Shadow Black Chrome Alloys, Viper Alarm, LED Interior lights, Tints
Covkiller
Post by Covkiller » Thu Apr 18, 2013 8:44 am
Sorry to hear that. Mine's fine so far. I'm off to MRC for a Dyno tomorrow late morning, I'll post the map in the evening.
Timster
Post by Timster » Fri Apr 19, 2013 10:58 pm
How did it go Covkiller?
Gavla... The reason I dismissed the Revo map was because they looked at me blankly when I asked if they could remove the cold-start. Too.
Covkiller
Post by Covkiller » Tue Apr 23, 2013 2:08 pm
RS4Magic Dyno run 19.04.2013.pdf
(298.55 KiB) Downloaded 82 times
Decoke pre+post results?
My car ran 399.4PS with a Revo remap pre decoke
I had a decoke and a revised Revo map on Wed17.04.2013 prior to an MRC dyno run on Fri 19.04.2013
Here ‘s my MRC Dyno results
Reading 3 – 425.9PS shows Revo’s map result post decoke
Reading 2 – 434.6PS Doug’s 1st attempt
Reading 1 – 439.5PS Doug’s best result
After Reading 3 Doug said that he could perform a safer map with even more performance. So I asked him to go ahead. Doug spent most of the day on my car, for which I am extremely grateful as the results speak for themselves.
Pre Decoke 399.4PS with Revo remap
Post Decoke 439.5PS with MRC remap
An amazing 40.1PS more
Thank you to Doug and the MRC boys.
Gavla
Post by Gavla » Tue Apr 23, 2013 2:25 pm
Good result there - bet your well pleased. ;-) Noticed much difference on the road from REVO?
Covkiller
Post by Covkiller » Tue Apr 23, 2013 2:32 pm
Yes, smoother, pulls harder and a lot faster.
Gavla
Post by Gavla » Tue Apr 23, 2013 2:35 pm
:biggrin3:
GlenRS
Post by GlenRS » Wed Apr 24, 2013 6:34 am
Why can't anyone just post a pre and post clean with exactly the same setup??? Loads of people want to see it, but we keep seeing posts with other mods at the same time......
Covkiller
Post by Covkiller » Wed Apr 24, 2013 7:30 am
Hi GlenRS If you're referring to my last post please can you point out where you see the additional mods and setup between my pre and post decoke breakdown.
Cheers Covkiller
WillRS
Post by WillRS » Wed Apr 24, 2013 8:27 am
Unfortunately I never had a chance to do the pre clean and after clean 3k - 8k rpm test however I got my car back from MRC yesterday afternoon having had amongst other things, the MRC full carbon clean.
my results were;
pre clean
369.7ps 413nm
371.4ps 415nm
post clean
401.2ps 446nm
401.8ps 447nm
pretty pleased with these results.
this is a TOTALLY standard car (the work I had done was purely maintenance) with 47,000 miles and is run on Shell V-Power (since december when I bought it) BUT my car is retarding the timing and if it wasn't Doug said it would be putting out pretty much the 414 they quote as stock so would be very pleased with that for a standard car.
I'm going to try running it on Tesco Momentum for a few weeks as I always get my v-power from same two stations and I think I need to rule out any fuel issues as everything else is working as it should - no vacuum leaks etc and Doug was a bit mystified as to why its doing what its doing if its running on v-power
I may then run it up to MRC for another dyno session to see if it is a fuel issue or just a mystery which never will be solved lol !
spikeyboy101
Post by spikeyboy101 » Wed Apr 24, 2013 1:27 pm
per earlier answer:
Just looked up the dyno results, already had the AmD map, k&n air filter and Milltek fitted 6 months beforehand
Start:
388 bhp and 318.1 lb/ft torque at 3903 rpm
After decoke:
406 bhp and 324.4 lb/ft torque at 3748 rpm
After decoke and vac fix:
431 bhp and 328 lb/ft torque at 5873 rpm
So the decoke along gave me 18 bhp gain.
GlenRS
Post by GlenRS » Fri Apr 26, 2013 5:01 pm
Covkiller wrote:Hi GlenRS If you're referring to my last post please can you point out where you see the additional mods and setup between my pre and post decoke breakdown.
Cheers Covkiller
Hi Covkiller,
Wasn't aimed specifically at your post, as there has been several calls for people to post up a direct comparison yet we appear to all still be waiting to see one. Even Spikeys post above is after a vac leak has been fixed and so im left wondering just how much difference if any the decoke made :bash:
But yes your post also falls into this, so i'll use it for example:
Covkiller wrote: Pre Decoke 399.4PS with Revo remap
As you can see this is not comparable as it uses a different map, and I assume a different dyno?
EDIT:
Rather impressed with WillRS post, that's a good gain from just a carbon clean!
Covkiller
Post by Covkiller » Fri Apr 26, 2013 5:41 pm
Hi GlenRS
Same MRC dyno used for all runs.
Please see Reading 3 for the pre and post results ie:
Pre Decoke 399.4PS with Revo Remap
Cheers Covkiller
watts6087
Post by watts6087 » Mon Apr 29, 2013 8:03 pm
I was pleased with my result! And I had the per cats gutted at Amd!
Users browsing this forum: No registered users and 216 guests
