n00b tuning question
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Olly_K
Post by Olly_K » Thu Oct 21, 2004 8:48 am
cant quite afford the AmD remap at the moment............but im itching it get something done on the car.
can i just fit the DV's ?
do AmD do them and how much do they cost fitted ?
I cant see them on their website...........just wondering if anyone here has done that
many thanks !
Nige_RS4
Post by Nige_RS4 » Thu Oct 21, 2004 8:54 am
Go for a short-shifter as your first mod. If you want to change your DV's, upgrade to the 710N DV's unless your planning massive increases in power. Also consider upgrading your TBB - not really a tuning mod, but a worthwhile upgrade nonetheless ;-)
BRETTCOLLINS
Post by BRETTCOLLINS » Thu Oct 21, 2004 10:53 am
I would change the exhaust on the car before remapping it. But DV's are a good place to start as well as TTB Hose on the front of the car.
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Dippy
Post by Dippy » Thu Oct 21, 2004 1:12 pm
Olly,
In case you're not aware, the only reason to change DVs is because of reliability. They do NOT improve performance, and can often result in reduced throttle response.
I can't remember how technical you are so if you know this already please excuse me.
There are 2 bad things that can happen to the air intake system on your car. The first is an air leak which causes the turbos to overwork. The second is solid matter getting into the engine. DV failure can cause both of these, and according to reports (i.e. not necessarily substantiated) both OEM and aftermarket DVs can cause these problems.
IMO (and it is no more than that), solid piston DVs give the lower risk of failure. However unless there is careful selection of spring tension, they can be slower to close resulting in loss of response between gearchanges. Also if the spring is too strong, they can be slow to open and cause boost spikes. Most can also be serviced.
The alternative is to use the newer diaphragm DV (as Nige has suggested). These are better for a stock engine than the ones it may have been supplied with. However like the TBB, they are still prone to failure because of the flexible diaphragm.
My recommendation is that if you are not going to chip the car for a while (e.g. at least 6 months), then do exactly what Nige has suggested. Although you may have long arms and can accept the stock gear lever throw (I could not and indeed it was my 1st priority mod).
2001 Silver S4 Avant
sash
Post by sash » Thu Oct 21, 2004 4:06 pm
dippy, what spring are you using in your DV?
[img]modules/pnCPG/Coppermine/albums/userpics/10727/sigimg2%7E0.gif[/img]
Olly_K
Post by Olly_K » Thu Oct 21, 2004 4:53 pm
thanks for advice guys.........the reason i was thinking about chaning the DV's was to hopefully get a bit more noise out of them !
I think i'll probably do the shortshift 1st.....anyone know how much this is all in (supplied and fitted ?)
Then i think the remap.
I dont think i will be changing the exhaust.........at this point in time anyways !
cliveyboy
Post by cliveyboy » Thu Oct 21, 2004 5:17 pm
excuse my ignorance (newbie here..!), but are DV's?
Nige_RS4
Post by Nige_RS4 » Thu Oct 21, 2004 5:31 pm
DV's = Dump Valve, but they're actually recirculating valves on the S4 - know as BPV's = ByPass Valves - confusing or what !
sash
Post by sash » Thu Oct 21, 2004 5:54 pm
Olly_K wrote:the reason i was thinking about chaning the DV's was to hopefully get a bit more noise out of them
DVs (i thought they were Diverter Valves) dont really make any noise you can hear cos they dont vent to atmosphere like Dump Valves do.
Olly_K
Post by Olly_K » Fri Oct 22, 2004 7:39 am
thanks sash, was kinda hoping for a bit of noise.......but oh well. Will probably take all your advice and get the short shift 1st, then i deffo doing the remap :)
cliveyboy
Post by cliveyboy » Fri Oct 22, 2004 8:09 am
anyone any idea how much short shift costs and where to do it?
Nige_RS4
Post by Nige_RS4 » Fri Oct 22, 2004 9:57 am
Send a pm to tanoga from this forum - he sells a highly regarded short shifter for the S4 / RS4.
sash
Post by sash » Fri Oct 22, 2004 11:26 am
Its £280 fitted at AMD but more than likely could be found for cheaper elsewhere.
sash
Post by sash » Fri Oct 22, 2004 12:13 pm
Olly_K, thats the order i did it in, shortshifter ...remap .(.. bipipe ... dvs ...suspension.)
Once you drive the car after the remap you will not stop smiling, i still find myself laughing out loud when i plant the accelerator, what a feeling!
changing the suspension was the next major improvement, it transformed my car from a boat to a go kart.
Start saving.
Dippy
Post by Dippy » Fri Oct 22, 2004 12:43 pm
sash wrote:dippy, what spring are you using in your DV?
Actually I can't remember. :oops:
I think Forge do 4 springs in yellow, green, blue and red. I think Red is the strongest. I know that I have the second strongest but I can't remember which colour it was. Possibly blue or green but I can't remember for certain.
Users browsing this forum: No registered users and 69 guests
